Last major Up-Date are these Posts
Oct. 2011
<object style="WIDTH: 640px; HEIGHT: 390px">&ampampampampnbsp
&ampampampampnbsp
<embed src="http://www.youtube.com/v/VPs42Mkw-7U?version=3" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" height="360" width="640"></object>
&ampampampampnbsp
March 29, 2011
This Link will take you to the Newest Post
on the "tigermachine".
It ia about changing to the
Boss R 19" Wheels, GT-500 Brakes Complete.
Hurst Shifter Mod with MGW Mechanism.
Steeda Ultra-Lite Springs.
This is the "Link" to the LAST Change made to the "tigermachine"
This is as of January 24, 2011.
New Saleen Stroked 302 Engine
along with other Major Changes.
Click on Link directly below to go to the
"POST"
http://www.imboc.com/forums/showthread.php?p=2117300&posted=1#post2117300
"POST"
The tigermachine is being Raced this (Week) in
Bowling Green, KY. at
"The Ford World Finals"
June 2010
<object height="385" width="480">
<embed src="http://www.youtube.com/v/imIjcfyaikA&hl=en_US&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" height="385" width="480"></object>
Post #1 You are on:
The 3rd Post is #685
Post #4 Link is Below:
The 4th Post is #781
Completed on Feb. 10, 2010
Click on the Link Below in Yellow:
http://www.imboc.com/forums/showthread.php?p=2029849#post2029849
Post #1 You are on:
There are "9" Total Post here to read
The 1st Post here that you are on "NOW".
Post #2 Link is Below:
Then Post #432the Link Below in "Black" will take you "Directly" to it
Post #3 Link is Below:
Done on Jan. 27, 2010
Link is Below in Black
Post #5 Link is Below:
493.41 RWHP Bullitt
Done on May 22nd, 2010
http://www.imboc.com/forums/showthread.php?p=2055399#post2055399
Post #6 Link is Below:
Last Up-Date is June 10, 2010
Below.
http://www.imboc.com/forums/showthread.php?p=2059885#post2059885
Post #7 Link is below
Last Up-Date is July 31, 2010
This is where it all began Below.
After you See & Read this Post
then you "Click" on the other
(Links-Above)
to get to eack "Change".
2nd row
Ron, Fran, John, Rick & Brent White (Mr. Brenspeed)
Twin 63.5mm bore (stock SVT Mustang is twin 60mm)
Last Pics Below on Build
Dave in the background taping up the hood
Changed-To
The Brenspeed "Custom" Grind NSR Blower Comp Cams
This Post is about adding
Eleanor Grille & Halo Fog Lights
http://www.imboc.com/forums/showpost.php?p=2070549&postcount=1568
Post #8 Link is belowEleanor Grille & Halo Fog Lights
Last up-date is August 15, 2010
the GT/CS
Front & Rear Fascias.
http://www.imboc.com/forums/showthread.php?p=2074407#post2074407
Link to Post #9 below
Last Brenspeed trip 12/29/2011 coverage ...
GT500 Rear End Assembly
BMR Lower control arm relocation brackets
JDM Transmission catch can
the GT/CS
(Links-Above)
Video of the
"574.74" New Flywheel H/P
as of
Jan. 03, 2010
2008 Bullitt Mustang
as of
Jan. 03, 2010
This Post is going to be for those that would like to See & Read
about Mods.
Also, for those that simply LUV Fast Mustangs.
about Mods.
I picked BRENSPEED in Pierceton, IN. to do my 08 Bullitt Mustang.
I would recommend them to anyone. They are a 1st class operation.
They also offer their Guest House to Out-of-State customers that
are traveling long distance. A simple phone call 1-574-594-9559
will "Reserve" it.
will "Reserve" it.
Here are Pics of the Guest House.
I stayed at the Guest House while the Bullitt was being Modded.
There was at times two Techs. (Mike & Dave) working on the Bullitt
at different times. Mike (Primary Tech) started on the Bullitt as soon
as they opened and stopped when they closed. He took a Very-Small
lunch break and was right back to work. Dave also as I said worked
on it some while Mike was working on a different area.
1st row
tiger & Karen White (Ms. Brenspeed)2nd row
Tigerhonaker's Mod-List
This has Been Up-datedAlso Added
COBRA JET BILLET ALUMINUM THROTTLE BODYTwin 63.5mm bore (stock SVT Mustang is twin 60mm)
Dave laying stencil on hood & marking where to Exactly-Cut for Shaker
Dave cutting hood out for Shaker
Hood has been cut out for Shaker
Dave with Cut-Out hood piece
"Thumpr" Stage-1 Comp Cams
These have been "Removed"
AndChanged-To
Comp Cam Phasers
"Thumpr" Comp Cams & Phasers being installed
Stock Cams removed
"Thumpr" Stage-1 Comp Cams installed
Parts roll in
The New "Bullitt-Mustang"
after
The BRENSPEED Saleen Supershaker
Modded Makeover
I really hope the ones Seeing & Reading this Post find it
Just returned from BRENSPEED
M-9926-CJ*
Service replacement for the 2008 Mustang FR500CJ race car
Fits in factory location on 2007-2009 SVT Mustang
Tested to over 800 hp in 2007-2009 SVT Mustang applications
Precision machined from billet aluminum to ensure consistency
Polished finish with machined Ford Racing logo
Tested to Ford original equipment specifications for cold and hot weather
Fully assembled, complete with throttle position sensor and actuator motor, ready to bolt on!
Uses OE gears to prevent gear bind and wear common with other aftermarket throttle bodies
Does not include calibration, calibration may be required in some applications
Mike tearing it down
Brisk Racing spark plugs ready to go in
MSD Coil Kit
MSD Coils ready to go in
MSD Coils installed
MSD Coils installed
Moser Axles, Eaton Posi unit, etc. on table
Moser Axles ready for install
Dave with Eaton Posi ready to install
Stock Posi unit removed
Stock Posi Unit on cart
Eaton Posi unit
Eaton Posi Unit
Eaton Posi Unit installed with Yellow Marker to set Depth
Moser Axles installed
Mike with Kooks Header to install
Mike holding Kooks Catted High-Flow H-Pipe to install
Kooks Header seen from engine bay
Complete Kooks Catted High-Flow H-Pipe installed W/Headers
Stock Lower Control Arm
Mike installing BMR Billet Lower control arm
BMR Panhard Bar relocation bracket
Mike carrying Steeda Adjustable Panhard Bar
Moser Axles, Eaton Posi, Steeda Heavy Duty Panhard Bar Brace
installed. Steeda Adjustable Panhard Bar hanging downSteeda Adjustable Panhard Bar, Eaton Posi Unit, FRPP Reinforced
Differental Cover, Moser Axles all installedDave Removed Stock fuel pump
Dave installing FRPP GT500 Fuel Pump Assembly
Dave holding the Complete wiring harness to the GT500 Fuel Pump
GT500 Fuel Pump Wiring routed into Passenger side footwell for install
MSD Coils installed and notice wiring harness on right. That is
where the New electronics are tied into. Stock intake is removedMike with stock intake removed and Steeda "Billet" Plates still installed underneath
Saleen Supercharger still in boxes
Saleen Stage-3 + Blower assembly
Saleen with Top Section removed for Shaker install
Look at the Pulley on the "Left" compared to the 3.2 pulley on the
"Right" installed. The 3.2 is rated at 11.5 Lbs. boost.
Mike (Left) & Todd (Right) ready to sit Saleen Shaker in place.
Mike, positioning Super-Shaker
Saleen Supershaker in place & wiring is completed on right side
FRPP 39 Lb Ford Racing Injectors on cart ready to be installed
FRPP 39 Lb Racing Injectors W/Fuel Rails being installed
Steeda Upgrade Belt Tensioner W/Billet Wheel
Steeda Upgrade Belt Tensioner W/Billet Wheel & V/10 Over Size Water Pump Pulley installed
Latest Saleen Supershaker
This Bracket in Front was "Made" by Dave because this Saleen
Blower is so New the Bracket shipped was incorrect. Dave made the
"Bracket" at the Shop and it looked like it came from Saleen. (Perfect) !!!
Saleen Supershaker upper parts installed (Red is Filter Cover for Rain)
MRT "Black" hood struts, Red Top Optima Battery & Top on Shaker
UPR oil catch can (Stainless)
Mike, is stripping the tape off & instaling 3M "Wider-Tape" to the
Shaker Hood Trim
Shaker Hood Trim
This is the 3M Wide Tape & Automotive Adhesion Promoter he uses
New 3M Wide Tape installed on Hood Trim piece
Mike installing Shaker Hood trim piece after cleaning with "Promoter"
Silverhorse Racing Black Billet Fuel Door installed
Billet Hood Pins W/No-Logo
Billet Hood Pins W/No-Logo Dave doing the "Drilling". Mike holding
the hood Steady. This was a very time consuming operation.
Mike finishing with drilling the final 8-Holes and using Blue Loctite
on screws so they would not back out. (Opinion) I would not do these at home.
Mike installing the Steeda Upgrade Heat Exchanger
Inner fender covers removed for Steeda Heat Exchanger install
Steeda Upgraded Heat Exchanger installed, 160 Degree Thermostat,
Royal Purple Ice
Royal Purple Ice
Mike starting to install the Autometer A/F, Fuel Pressure, Boost
Gauge & Raptor Shift Light
Here is a pic of the back side of the Gauges showing all the wires
Drivers side where the Gauges wire gets hooked up. A lot of wire.
All wiring is "Soldered" & Heat Shrink Tubing used.
Inside drivers door showing wiring to be connected, soldered
All Gauges/Raptor Shift Light installed. Mike took the time to set my
dash lights the exact Blue-Color the New Gauges were. He also
hooked them up to the (Dimmer) for night driving.
Bullitt was Test Driven & then Fans were put
underneath to "Cool" it down
for next install
for next install
Saleen came in for some added (Power) & Brake Upgrade.
Bullitt is waiting for "Lunch-Break" to end
Mike is dropping the transmission to install the
(Spec Stage-2 + Clutch) & (Spec Steel Flywheel)
Transmission, Dynotech 3.5" Aluminum Driveshaft is out.
New Spec Stage-2 + Clutch & Steel Flywheel
being installed
being installed
Spec-2 + Clutch, Rated at 669 Lbs. Torque, Pressure Plate, & Steel Flywheel ready for install
Spec Steel Flywheel installed
Spec Clutch Disc installed
Spec Pressure Plate installed
CHE Torque Limiting Brace
CHE Torque Limiting Brace, Kooks Headers W/High Flow Cats, H-Pipe from underneath
BMR Front Driveshaft Loop installed
BMR Front Driveshaft Loop Installed
Chandler installing the Saleen Valve Stem Caps (Match Supershaker)
Todd hooking Bullitt up for Brent (Mr. BRENSPEED) to do Dyno Runs
Bullitt Locked in Place on Dyno by "Todd" the Main-Man !!!
Brent with Laptop in hand
and setting Dyno Computer up
for Pulls
for Pulls
Inside Bullitt looking at Tuner, Laptop etc.
Next Picture will be "Close-Up" of Laptop Screen
Brent in Bullitt now doing the Dyno-Runs
Major Wide-Screen Display to view from outside Dyno Room
through Multiple Windows
My Bullitt on 1-Dyno Run
Last Pull on Dyno is in "RED" on Graph
Print out from Last Dyno Pull
This is an overlay showing the (Flywheel Horsepower) in "Yellow".
This is what you (Usually) read in Magazines on all vehicles like the
Shelby GT500, SS Camaro, SRT8 Challeger, Charger etc.
Gives you an idea of just how STRONG this 2008 Bullitt Mustang is.
Here are the things I did "Before" I went to BRENSPEED in
Preparation for the (Increased-Power).
Custom Limited Edition Plate along with Strut-Tower-BracePreparation for the (Increased-Power).
has been Removed
Here is the New Custom Plate"Exact-Duplicate"
Custom Plate fits right in
the Rectangle Box
the Rectangle Box
New Tires that are the Exact same ones that came on the GT500
Mustang.
Mustang.
Painted for 1-week underneath every Rusted place I could find. It
was so HOT I had to cover up to keep from Scorching my Legs on
Top and Bottom against Asphalt Driveway.
Installed H&R Hub Centric 25MM Front & Rear Wheel Spacers.
The rear spacers go on with (No-Problem) & Wheels fit Great
But the Front Spacers fit okey but you have to "Cut" Off your
existing 5-Wheel Studs. They stick out to "Far". This is how you
should do the cutting. High Speed Dremel Tool W/Cutting Blade.
Look at this Pic and notice I left the Wheel-Lugs on next to the
Lug I was Cutting-Off. This way No-Messed up Threads.
Here are the Pieces that were Cut-Off. Notice they are different
Heights.
Heights.
This pic shows the Finished Product. After cutting those Lugs off.
You have to then use the Dremel with a Grinding-Wheel. To make
all the Cut-Off-Studs as close as possible to the same (Length).
You, Do-Not actually Cut or Grind any of the (Threads). You are
only working with the end of the studs before you get to the
Threads. Takes time but (Not-Hard) to do.
I sent my 2-Back Stock Wheels to James at Weldcraft to have them
(Widened). They were 8.5" stock and they added 1.5" to make them
10" Wide. Shelby GT500 has 9.5" Wheels Front & Rear.
I know many of you are interested in this so you can retain the
Stock Wheels, so here are many Pics of the Widened Wheels.
Here are the 2-Rear wheels Mounted & Balanced
This one took only 1-Weight
This one took 2-Small Weights
Here is the (Front-Side) of the Wheels as I removed them from the
Very-Well-Packed Box.
Notice, Not a Mark, Period !!!
Here are 2-Pics of the Box they came back in.
They were (Double-Boxed) and then had Bubble-Wrap.
Here are 3-Pics of the Rear of my Bullitt.
I changed the Fake Gas Cap to a
(Silverhorse Racing Black Billet Trunk Emblem).
I Added the (Silverhorse Racing Black Honeycomb Taillight Panel) to
match the Front. BRENSPEED then Added the (Silverhorse Racing
Billet Fuel Door).
Billet Fuel Door).
Before
After
Here is a Pic of My-Bullitt sitting outside for Months while doing
the above changes.
the above changes.
The Bullitt with "Giant tiger Claws"
ready to leave on Saturday
Al & His Son Aaron the morning we are leaving
Tiger in Front, Chandler on Left, Rick on Right
the Saturday Morning I left
after
Modded Makeover
informative as well as interesting. My wish is to "Provide"
those of you with Limited Performance Knowledge a
"Resource" here that is (Factual).
Happy-Modding Everyone ..........
The-End !!!
Terry Honaker aka "tigerhonaker"
Here is the "Action" Video
http://www.youtube.com/watch?v=5KTt4wwRxFEHere is the "Action" Video
With
this Purchase & Install
COBRA JET BILLET ALUMINUM THROTTLE BODYthis Purchase & Install
M-9926-CJ*
Top of Saleen Supershaker off
Stock Throttle Body Removed
Stock Throttle Body on Table
Here are Both the Stock & New FRPP
Throttle Bodies Pics
Mike, installing the New FRPP Throttle Body
FRPP Installed
Mike, installing top of Supershaker
Mike completed install & Loaded New Tune.
Here I am arriving at Comfort InnBullitt W/Brenspeed Cover on
Next morning getting ready to pull
cover off & Leave
cover off & Leave
This is interesting I think. These Pics were taken
by a former Ford Engineer that was traveling.
He saw the Bullitt the night before and
was waiting when I came out to leave.
I started it up to let it Warm-Up and
when I came back out he was checking the
Bullitt out.
He shot these Pics and was Excited over the way
the Bullitt now Sounded and the New
H/P & Torque figures.
Bullitt out.
I drove back to BRENSPEED Performance and
waited for Dyno Don to show-up from
Indianapois, IN.
He was going to drive the Bullitt back and
then feed me at The Crackle Barrel
Here's Don getting the 08 Bullitt Keyswaited for Dyno Don to show-up from
Indianapois, IN.
Good Times !!!
Oh,
From trying to follow Don on the way to Indianapolis, IN. I think he was having
a Great time. :smile: Or it certainly Sounded like it from where I was sitting. :lol:
He will have to tell what He thought.
