1,021.81 Flywheel H/P, 817.45 RWHP, Video & Post # 9040
846K views 11K replies 254 participants last post by  mrt2you
#1 · (Edited)
Last major Up-Date are these Posts
Oct. 2011
<object style="WIDTH: 640px; HEIGHT: 390px">&ampampampampampnbsp
<embed src="http://www.youtube.com/v/VPs42Mkw-7U?version=3" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" height="360" width="640"></object>
March 29, 2011
This Link will take you to the Newest Post
on the "tigermachine".
It ia about changing to the
Boss R 19" Wheels, GT-500 Brakes Complete.
Hurst Shifter Mod with MGW Mechanism.
Steeda Ultra-Lite Springs.
This is the "Link" to the LAST Change made to the "tigermachine"
This is as of January 24, 2011.
New Saleen Stroked 302 Engine
along with other Major Changes.
Click on Link directly below to go to the
"POST"
http://www.imboc.com/forums/showthread.php?p=2117300&posted=1#post2117300
The tigermachine is being Raced this (Week) in
Bowling Green, KY. at
"The Ford World Finals"
June 2010
<object height="385" width="480">
<embed src="http://www.youtube.com/v/imIjcfyaikA&hl=en_US&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" height="385" width="480">
</object>
Post #1 You are on:
There are "9" Total Post here to read
The 1st Post here that you are on "NOW".
Post #2 Link is Below:
Then Post #432
the Link Below in "Black" will take you "Directly" to it
Post #3 Link is Below:
The 3rd Post is #685
Done on Jan. 27, 2010
Link is Below in Black
Post #4 Link is Below:
The 4th Post is #781
Completed on Feb. 10, 2010
Click on the Link Below in Yellow:
http://www.imboc.com/forums/showthread.php?p=2029849#post2029849
Post #5 Link is Below:
493.41 RWHP Bullitt
Done on May 22nd, 2010
http://www.imboc.com/forums/showthread.php?p=2055399#post2055399
Post #6 Link is Below:
Last Up-Date is June 10, 2010
Below.
http://www.imboc.com/forums/showthread.php?p=2059885#post2059885
Post #7 Link is below
Last Up-Date is July 31, 2010
This Post is about adding
Eleanor Grille & Halo Fog Lights
http://www.imboc.com/forums/showpost.php?p=2070549&postcount=1568
Post #8 Link is below
Last up-date is August 15, 2010
the GT/CS
Front & Rear Fascias.
http://www.imboc.com/forums/showthread.php?p=2074407#post2074407
Link to Post #9 below
Last Brenspeed trip 12/29/2011 coverage ...
GT500 Rear End Assembly
BMR Lower control arm relocation brackets
JDM Transmission catch can
This is where it all began Below.
After you See & Read this Post
then you "Click" on the other
(Links-Above)
to get to eack "Change".
Video of the
"574.74" New Flywheel H/P
as of
Jan. 03, 2010
2008 Bullitt Mustang
This Post is going to be for those that would like to See & Read
about Mods.
Also, for those that simply LUV Fast Mustangs.
I picked BRENSPEED in Pierceton, IN. to do my 08 Bullitt Mustang.
I would recommend them to anyone. They are a 1st class operation.
They also offer their Guest House to Out-of-State customers that
are traveling long distance. A simple phone call 1-574-594-9559
will "Reserve" it.
Here are Pics of the Guest House.
I stayed at the Guest House while the Bullitt was being Modded.
There was at times two Techs. (Mike & Dave) working on the Bullitt
at different times. Mike (Primary Tech) started on the Bullitt as soon
as they opened and stopped when they closed. He took a Very-Small
lunch break and was right back to work. Dave also as I said worked
on it some while Mike was working on a different area.
1st row
tiger & Karen White (Ms. Brenspeed)
2nd row
Ron, Fran, John, Rick & Brent White (Mr. Brenspeed)
Tigerhonaker's Mod-List
This has Been Up-dated
Also Added
COBRA JET BILLET ALUMINUM THROTTLE BODY
Twin 63.5mm bore (stock SVT Mustang is twin 60mm)
Last Pics Below on Build
Dave in the background taping up the hood
Dave laying stencil on hood & marking where to Exactly-Cut for Shaker
Dave cutting hood out for Shaker
Hood has been cut out for Shaker
Dave with Cut-Out hood piece
"Thumpr" Stage-1 Comp Cams
These have been "Removed"
And
Changed-To
The Brenspeed "Custom" Grind NSR Blower Comp Cams
Comp Cam Phasers
"Thumpr" Comp Cams & Phasers being installed
Stock Cams removed
"Thumpr" Stage-1 Comp Cams installed
Parts roll in
Brisk Racing spark plugs ready to go in
MSD Coil Kit
MSD Coils ready to go in
MSD Coils installed
MSD Coils installed
Moser Axles, Eaton Posi unit, etc. on table
Moser Axles ready for install
Dave with Eaton Posi ready to install
Stock Posi unit removed
Stock Posi Unit on cart
Eaton Posi unit
Eaton Posi Unit
Eaton Posi Unit installed with Yellow Marker to set Depth
Moser Axles installed
Mike with Kooks Header to install
Mike holding Kooks Catted High-Flow H-Pipe to install
Kooks Header seen from engine bay
Complete Kooks Catted High-Flow H-Pipe installed W/Headers
Stock Lower Control Arm
Mike installing BMR Billet Lower control arm
BMR Panhard Bar relocation bracket
Mike carrying Steeda Adjustable Panhard Bar
Moser Axles, Eaton Posi, Steeda Heavy Duty Panhard Bar Brace
installed. Steeda Adjustable Panhard Bar hanging down
Steeda Adjustable Panhard Bar, Eaton Posi Unit, FRPP Reinforced
Differental Cover, Moser Axles all installed
Dave Removed Stock fuel pump
Dave installing FRPP GT500 Fuel Pump Assembly
Dave holding the Complete wiring harness to the GT500 Fuel Pump
GT500 Fuel Pump Wiring routed into Passenger side footwell for install
MSD Coils installed and notice wiring harness on right. That is
where the New electronics are tied into. Stock intake is removed
Mike with stock intake removed and Steeda "Billet" Plates still installed underneath
Saleen Supercharger still in boxes
Saleen Stage-3 + Blower assembly
Saleen with Top Section removed for Shaker install
Look at the Pulley on the "Left" compared to the 3.2 pulley on the
"Right" installed. The 3.2 is rated at 11.5 Lbs. boost.
Mike (Left) & Todd (Right) ready to sit Saleen Shaker in place.
Mike, positioning Super-Shaker
Saleen Supershaker in place & wiring is completed on right side
FRPP 39 Lb Ford Racing Injectors on cart ready to be installed
FRPP 39 Lb Racing Injectors W/Fuel Rails being installed
Steeda Upgrade Belt Tensioner W/Billet Wheel
Steeda Upgrade Belt Tensioner W/Billet Wheel & V/10 Over Size Water Pump Pulley installed
Latest Saleen Supershaker
This Bracket in Front was "Made" by Dave because this Saleen
Blower is so New the Bracket shipped was incorrect. Dave made the
"Bracket" at the Shop and it looked like it came from Saleen. (Perfect) !!!
Saleen Supershaker upper parts installed (Red is Filter Cover for Rain)
MRT "Black" hood struts, Red Top Optima Battery & Top on Shaker
UPR oil catch can (Stainless)
Mike, is stripping the tape off & instaling 3M "Wider-Tape" to the
Shaker Hood Trim
This is the 3M Wide Tape & Automotive Adhesion Promoter he uses
New 3M Wide Tape installed on Hood Trim piece
Mike installing Shaker Hood trim piece after cleaning with "Promoter"
Silverhorse Racing Black Billet Fuel Door installed
Billet Hood Pins W/No-Logo
Billet Hood Pins W/No-Logo Dave doing the "Drilling". Mike holding
the hood Steady. This was a very time consuming operation.
Mike finishing with drilling the final 8-Holes and using Blue Loctite
on screws so they would not back out. (Opinion) I would not do these at home.
Mike installing the Steeda Upgrade Heat Exchanger
Inner fender covers removed for Steeda Heat Exchanger install
Steeda Upgraded Heat Exchanger installed, 160 Degree Thermostat,
Royal Purple Ice
Mike starting to install the Autometer A/F, Fuel Pressure, Boost
Gauge & Raptor Shift Light
Here is a pic of the back side of the Gauges showing all the wires
Drivers side where the Gauges wire gets hooked up. A lot of wire.
All wiring is "Soldered" & Heat Shrink Tubing used.
Inside drivers door showing wiring to be connected, soldered
All Gauges/Raptor Shift Light installed. Mike took the time to set my
dash lights the exact Blue-Color the New Gauges were. He also
hooked them up to the (Dimmer) for night driving.
Bullitt was Test Driven & then Fans were put
underneath to "Cool" it down
for next install
Saleen came in for some added (Power) & Brake Upgrade.
Bullitt is waiting for "Lunch-Break" to end
Mike is dropping the transmission to install the
(Spec Stage-2 + Clutch) & (Spec Steel Flywheel)
Transmission, Dynotech 3.5" Aluminum Driveshaft is out.
New Spec Stage-2 + Clutch & Steel Flywheel
being installed
Spec-2 + Clutch, Rated at 669 Lbs. Torque, Pressure Plate, & Steel Flywheel ready for install
Spec Steel Flywheel installed
Spec Clutch Disc installed
Spec Pressure Plate installed
CHE Torque Limiting Brace
CHE Torque Limiting Brace, Kooks Headers W/High Flow Cats, H-Pipe from underneath
BMR Front Driveshaft Loop installed
BMR Front Driveshaft Loop Installed
Chandler installing the Saleen Valve Stem Caps (Match Supershaker)
Todd hooking Bullitt up for Brent (Mr. BRENSPEED) to do Dyno Runs
Bullitt Locked in Place on Dyno by "Todd" the Main-Man !!!
Brent with Laptop in hand
and setting Dyno Computer up
for Pulls
Inside Bullitt looking at Tuner, Laptop etc.
Next Picture will be "Close-Up" of Laptop Screen
Brent in Bullitt now doing the Dyno-Runs
Major Wide-Screen Display to view from outside Dyno Room
through Multiple Windows
My Bullitt on 1-Dyno Run
Last Pull on Dyno is in "RED" on Graph
Print out from Last Dyno Pull
This is an overlay showing the (Flywheel Horsepower) in "Yellow".
This is what you (Usually) read in Magazines on all vehicles like the
Shelby GT500, SS Camaro, SRT8 Challeger, Charger etc.
Gives you an idea of just how STRONG this 2008 Bullitt Mustang is.
Here are the things I did "Before" I went to BRENSPEED in
Preparation for the (Increased-Power).
Custom Limited Edition Plate along with Strut-Tower-Brace
has been Removed
Here is the New Custom Plate
"Exact-Duplicate"
Custom Plate fits right in
the Rectangle Box
New Tires that are the Exact same ones that came on the GT500
Mustang.
Painted for 1-week underneath every Rusted place I could find. It
was so HOT I had to cover up to keep from Scorching my Legs on
Top and Bottom against Asphalt Driveway.
Installed H&R Hub Centric 25MM Front & Rear Wheel Spacers.
The rear spacers go on with (No-Problem) & Wheels fit Great
But the Front Spacers fit okey but you have to "Cut" Off your
existing 5-Wheel Studs. They stick out to "Far". This is how you
should do the cutting. High Speed Dremel Tool W/Cutting Blade.
Look at this Pic and notice I left the Wheel-Lugs on next to the
Lug I was Cutting-Off. This way No-Messed up Threads.
Here are the Pieces that were Cut-Off. Notice they are different
Heights.
This pic shows the Finished Product. After cutting those Lugs off.
You have to then use the Dremel with a Grinding-Wheel. To make
all the Cut-Off-Studs as close as possible to the same (Length).
You, Do-Not actually Cut or Grind any of the (Threads). You are
only working with the end of the studs before you get to the
Threads. Takes time but (Not-Hard) to do.
I sent my 2-Back Stock Wheels to James at Weldcraft to have them
(Widened). They were 8.5" stock and they added 1.5" to make them
10" Wide. Shelby GT500 has 9.5" Wheels Front & Rear.
I know many of you are interested in this so you can retain the
Stock Wheels, so here are many Pics of the Widened Wheels.
Here are the 2-Rear wheels Mounted & Balanced
This one took only 1-Weight
This one took 2-Small Weights
Here is the (Front-Side) of the Wheels as I removed them from the
Very-Well-Packed Box.
Notice, Not a Mark, Period !!!
Here are 2-Pics of the Box they came back in.
They were (Double-Boxed) and then had Bubble-Wrap.
Here are 3-Pics of the Rear of my Bullitt.
I changed the Fake Gas Cap to a
(Silverhorse Racing Black Billet Trunk Emblem).
I Added the (Silverhorse Racing Black Honeycomb Taillight Panel) to
match the Front. BRENSPEED then Added the (Silverhorse Racing
Billet Fuel Door).
Before
After
Here is a Pic of My-Bullitt sitting outside for Months while doing
the above changes.
The Bullitt with "Giant tiger Claws"
ready to leave on Saturday
Al & His Son Aaron the morning we are leaving
Tiger in Front, Chandler on Left, Rick on Right
the Saturday Morning I left
The New "Bullitt-Mustang"
after
The BRENSPEED Saleen Supershaker
Modded Makeover
I really hope the ones Seeing & Reading this Post find it
informative as well as interesting. My wish is to "Provide"
those of you with Limited Performance Knowledge a
"Resource" here that is (Factual).
Happy-Modding Everyone ..........
The-End !!!
Terry Honaker aka "tigerhonaker"
Here is the "Action" Video
http://www.youtube.com/watch?v=5KTt4wwRxFE
Just returned from BRENSPEED
With
this Purchase & Install
M-9926-CJ*
Service replacement for the 2008 Mustang FR500CJ race car
Fits in factory location on 2007-2009 SVT Mustang
Tested to over 800 hp in 2007-2009 SVT Mustang applications
Precision machined from billet aluminum to ensure consistency
Polished finish with machined Ford Racing logo
Tested to Ford original equipment specifications for cold and hot weather
Fully assembled, complete with throttle position sensor and actuator motor, ready to bolt on!
Uses OE gears to prevent gear bind and wear common with other aftermarket throttle bodies
Does not include calibration, calibration may be required in some applications
Mike tearing it down
Top of Saleen Supershaker off
Stock Throttle Body Removed
Stock Throttle Body on Table
Here are Both the Stock & New FRPP
Throttle Bodies Pics
Mike, installing the New FRPP Throttle Body
FRPP Installed
Mike, installing top of Supershaker
Mike completed install & Loaded New Tune.
Here I am arriving at Comfort Inn
Bullitt W/Brenspeed Cover on
Next morning getting ready to pull
cover off & Leave
This is interesting I think. These Pics were taken
by a former Ford Engineer that was traveling.
He saw the Bullitt the night before and
was waiting when I came out to leave.
I started it up to let it Warm-Up and
when I came back out he was checking the
Bullitt out.
He shot these Pics and was Excited over the way
the Bullitt now Sounded and the New
H/P & Torque figures.
I drove back to BRENSPEED Performance and
waited for Dyno Don to show-up from
Indianapois, IN.
He was going to drive the Bullitt back and
then feed me at The Crackle Barrel
Here's Don getting the 08 Bullitt Keys
Good Times !!!
Oh,
From trying to follow Don on the way to Indianapolis, IN. I think he was having
a Great time. :smile: Or it certainly Sounded like it from where I was sitting. :lol:
He will have to tell what He thought.
tigerhonaker​
#103 ·
shortymustang said:
Yeah, what happend to all the takeoffs?
Frank,
Al's Son Aaron bought the Steeda Mods from Brenspeed while he was hanging out.
The rest of the Take-Offs are for Sell ..........
That would be the Bullitt Take-Offs !!!
Like CAI, Complete Bullitt Exhaust from Manifolds back.
FRPP 3:73 Gears, Bullitt Shifter without the Aluminum Shift Knob.
#104 ·
Feshdogg said:
This is EXACTLY what I encountered with the H & R 25 mm spacers. When I first installed the spacers, I started with the rears and saw that they were flush. So when I put the fronts on, I did not think to check them. However, after driving for a couple days, I noticed a steering wheel shimmy from around 30 - 65 MPH. It was not that noticeable but enough to worry me.
I tried to figure out what was causing it before I removed the wheels. But when I did, I saw the indentations on the pockets of the front wheels. Scary!!! I had been driving quite a bit all over LA freeways for days! Got the Dremel out, did exactly what Terry did, NO PROBLEMS.
Just be aware that you will more than likely need to do this if you have the stock wheels and the H & R DRM 25 mm spacers that do not REPLACE the studs. Check your clearances first!
I really like the way they look now, but they exaggerate the fender gap, in my opinion. Now just gotta lower it! Nice, quality spacers though. "They're made in Germany, you know the Germans make good stuff" (<--- quoting 'Vince' from Sham Wow :lol: )
Steve
Steve,
Very Well said ..........
We are on the Same-Page !!!
I measured the Rears and then the fronts and knew there was going to have to be some
modifying to the Stock Wheel Studs on the Front.
One Dremel coming up.
#105 ·
Wolfie said:
Ok Terry you win!!! I have always said "go big or go home".
Beautiful Bullitt you have, now bring on the SS's and SRT/8's.
Wolfie,
Like they say (Stay on the Porch) if you can't play with the Big-Dogs
Thanks, for dropping by and checking out the New Updated Bullitt.
It is going to be a real Riot once some Break in Miles have been put on it.
Thanks again,
#106 ·
SwissBullitt said:
Terry I don't know what to say...Just your Bullitt is awesome!!!:shock: :shock: :shock:
Congratulations...
Please take it to the strip once to see a 11 seconds Bullitt in Action :badgrin:
Chris,
That will more than likely not take place until next season.
Thanks Pal for the Compliment as you have a Very Strong Bullitt there in Switzerland.
I can already tell I am going to really like driving this "Street Bullitt" around town.
#107 ·
9mmBullitt said:
Wow, Terry. Incredible list of mods. Seems you took your time and put it together exactly like you wanted. Enjoy it!
Hello Brad,
Thanks Man for taking the time to check out the Post.
It has been in the planning stage for a long time it seems.
But, I will have to say when I heard it fire up it was an AWESOME Sounding Machine.
It is the way I wanted it in the H/P and Looks department.
Thanks again,
#108 ·
jimbo020 said:
Terry, thanks for the info about Quality Printing. I also agree with your thinking behind the mods to the B rather than buying a Shelby. Just slide in behind the wheel of a Bullitt Mustang, slip on your Persol sunglasses put her in first gear and enjoy a ride back in time -- or -- a put yourself in a new frame of mind. Either way, YOU WIN!
Thats how I feel when I drive mine. ;)
Jim,
Your Welcome and Jim does Great Work.
We are on the exact same page in regards to the Bullitt Versus a GT500 Shelby.
The GT500 Shelby is an Awesome Machine for sure.
But, IMHO, nothing touches the Limited Edition 2001/2008/2009 Bullitt Mustangs.
As I have said many times here, just add the H/P and Mods as you really want your
Bullitt to be.
#109 ·
cpd0924 said:
Iam Speechless, Great Job Terry You Even Out Did Yourself On This One.
My Man John from the Windy-City,
Hi Pal.
So, you think I out did myself on this Little-Ole-Bullitt Mustang :badgrin: :badgrin: :badgrin:
Man, I checked the List
and then Checked it again with (Cathy).
Cathy said, (I think you are in) Big Dog
John, now all I need is this "Label" on the Sunvisor to be (Complete)
#110 · (Edited)
LeadFoot said:
Wow...awesome Bullitt you've got there Tiger. I love what you did with the ID plate. I also never thought I'd say this to a man but your rear end looks pretty nice too. :lol:
However............if I dropped 21 large and wound up under 500 ponies at the rear wheels I would be pretty disappointed. I suppose though that a good chunk of the total is not related to hp production and, if you knew going in you wouldn't reach 500 then I guess it's all good.
Enjoy it.
Hi Rich,
I see where you are coming from on the 500 RWHP and 21 Large spent.
As you point out if was you, you would be Disappointed in a Major-Way.
But, man, don't we Hate to see that word, because we just know something is coming our way.
In reality I was planning on anything above "450 RWHP".
So in my case I got the Bonus of another 28 H/P.
Also, I know you don't perhaps know me, but if I really was looking for 500 RWHP ???
Trust me it would have been there .........
Unlike many people I was building a Strong Running Street Bullitt with Factory Street Tires.
Not, the Cheater Slicks that as soon as it Sprinkles Rain one slows up, Immediately or
chances tearing up their Bullitt.
So, to have 478 RWHP on Street Tires is more than Sufficient on a Bullitt Mustang.
Watch the Video "Close" and do you really (Honestly) think it needs another 22 RWHP ???
Once you get to where this Bullitt is in RWHP on Street Factory Tires it is nothing more than
IMHO (Bragging-Rights) to ones Buddies.
And there is nothing Wrong with that, if that is where a person is in their Life. I have been
there many-many times over in the past.
How many people do any of us really know that are driving a Street Mustang around with
562 Flywheel Horsepower ???
I can answer that, in my case I don't really know anyone unless I drive back to BRENSPEED.
As you say in the above comment the Dollars were spread out for a Complete Upgraded
Bullitt with all things taken into consideration. 500 RWHP was "Never" part of the Goal.
Like you say I don't really tell other Men I really like what you have done with your "Rear-End".
Thanks much for the Compliments on the Bullitt and it's New Look Rear-End. :badgrin:
It is an AWESOME Street Machine and it is a very complete package to drive anywhere.
Say, I do want to say to you that my comments on the 500 RWHP are meant to "Answer"
your Comment on same.
My Comments are in No-Way to be taken as anything other than a simple explanation of
what I was looking for and why 500 RWHP is just not a Big Deal in this Newly-Modded-Bullitt.
Thanks for Posting and your Compliments and Questions.
#111 ·
Holy Smoke & Great Balls of Fire!
Tiger, :clap: :clap: :clap: :clap: :clap:
What a Mind Blowing Modification. You have the absolute Epitamy of a Bullitt Fantacy come true. I don't know what you were doing for your driving habits and time on the road before this but what is it Now? Not only do you have one great Bullitt but what a great photographic presentation of your adventure.
:drool2: :drool2: :drool2: :drool2: :drool2: :drool2:
#113 ·
Terry,
What a BEAST! That thing will put you back in your seat every time you push the "go" pedal down.
Thanks for sharing and ENJOY IT! :cool:
#114 · (Edited)
JC2954 said:
Wow Big-T, that car is just SICK!!!
You are THE MAN!
Double-props to Brenspeed; by the look of things - they'd be The Shop to go to if you want it done Right!
Scott,
AWESOME Bullitt now Big Guy
BRENSPEED does have their game plan down.
If one lives within driving distance I have No-Problem recommending them. Heck I say take
some vacation and get the Bullitt done at the same time. Call ahead and make a Reservation
for staying at the Guest House. FREE, and it is Nice, Clean and has a High-Speed Computer
in a room by itself.
They started in the morning and only stopped for a brief lunch and right back to work.
You know Scott that I really like your Mustang and have said so many times here on IMBOC.
So I Appreciate your Compliments to me on my New Modded Bullitt Power-House !!!
It is SICK if you hear it Fire-Up while you are standing by it.
The 1st time I heard it Start-Up I have to admit it (Immediately) put a Smile on my Face.
Man, Good Times :clap:
tiger said to say Hello to You
#115 ·
What a Mind Blowing Modification. You have the absolute Epitome of a Bullitt Fantasy come true. I don't know what you were doing for your driving habits and time on the road before this but what is it Now? Not only do you have one great Bullitt but what a great photographic presentation of your adventure.
Hello Joe,
Thanks for Stopping by and Posting.
My driving habits are pretty normal really.
I just like to take off and then push the Go-Pedal to where the tires Break-Loose, then shift to 2nd and Repeat the experience I just had in 1st Gear.
Now, I can do this all the way through 3rd Gear and it Skating around.
I am glad you and others enjoyed the Post as well as the "Action" Video Brent White did of the Bullitt.
It was well worth the time it took after seeing the response from so many Members here.
Thanks again,
#116 ·
Jester67 said:
Blower :cool:
Other mods :cool:
hood pins :???: :neutral: I understand them but I like the hidden ones
the Brenspeed logo's :cry:
I just Don't see getting a Bullitt and posting a look at me sicker on it.
But it is your car and I am willing to bet it is a VERY fun ride.
Hi Jester,
At my age I don't really care to much about Hidden Hood Pins.
The BRENSPEED Graphics are a Show of (Admiration & Appreciation) to Brent White for a
Great Performance Shop as well as a Terrific Job on my Bullitt Mustang.
That might be an Ole-School thing ..........
Hey, looks like I did about a 50/50 job with your Likes & Dislikes.
Heck, I could of had like a lot Worse Rating so I think all is okey.
Thanks for taking time to Post and I Appreciate "Your-Opinions" and the right to Post them.
Even though I chose to go a different direction on some things.
Great to be in the USA and be able to be an "Individual" and make our own Choices.
Thanks Again,
#117 ·
Bullitt3817 said:
Terry,
Hi Perry,
Man it has been some time since I have heard from you.
Way back when I did the Gift thing for the B-Man (Mike).
I think it will be a "Beast" on the Street for sure.
The little I have driven it as far as Power it "Literally" Jumps like you see in the Video.
I wish I could have pulled off some time back when I suggested in "The Suggestion Box"
to have ALL 2001/2008/2009 400 H/P Plus Bullitts together in one place. It would have been
Fun to of been able for All of the High Horsepower Bullitt Members to See & Discuss their
cars.
I'm glad you saw the Post and decided to stop by and check it out.
Hope you saw the Link to the Video Brent White did of it.
Thanks again,
#120 ·
You've brought up some excellent points Terry. It makes tons of sense when I look at it that way.
I am now wrestling with myself on buying the rear honeycomb panel with the billet medallion and fuel door.
That looks VERY sharp.
Be careful in that thing!
Rich
tigerhonaker said:
Hi Rich,
#121 ·
It is closer to 90/10 or 95/5 like/dislike. The pins and logo just give away the terror that is under the plain green wrapper. To me the more understated the better. But as you stated this is the reason that we love this country and this site where we can still share our opinions and not have to worry about someone getting angry. So when are you taking a road in the Memphis direction so I can see this thing in person.
#122 ·
It was a helluva week for you, Big Guy!!!
I'll say this much, when you take on a project, you do it in a big way! Many thanks to you for everything and the fun times we had this past week at Brenspeed. Great post and pics also. I can't help but wonder what 2010 will bring for mod-minded Bullittheads! Here's 2 more pics.....
No more nubbies on those Goodyear tire treads!!! :bigguns:
The last pic before heading home to Franklin, TN. What a week it was.........:clap:
#123 ·
Branomano08BlackBullitt said:
Hey Terry very nice.. very very nice... but, I gotta ask as I am sure you are well aware.. you are dangerously close to the limits of the stock rotating assembly with your new setup there. What are your plans for when you throw something? With over 500 Horses and 11.5 PSI it is like a ticking bomb.
After spending over $20 grand on mods I don't think he's too concerned about blowing the motor
#124 ·
Crazy man! I thought I was bad about spending money. I just showed my wife this thread just to prove I'm not the only one or even close to the worst one! :lol: :lol: That is some awesome build. I really like the cams. They just say "old school muscle." Nice job Terry. :clap:
#125 ·
wow. that is quite the list of mods!!!! Great job!!! yours is sounding and looking more and more like mine everyday!!!:clap: :rotfl: :rotfl: :clap2: :eek: :eek:
