I've researched this site and can't find advice on what Plugs and wires are good / best for DHG 1835. She's at 114k and it's time. Any ideas on best Plugs and wires and where to get them?
you don't have plug wires. you have coil on plugs for the 01 bullitt. just use Motorcraft replacement plugs and should be good to go. be sure and blow out the spark plug tubes prior to removing the plugs, MAKE SURE YOU TORQUE THEM PROPERLY!!!!! HEADS AND MOTOR NEED TO BE COLD. these heads use a short thread and are easily installed incorrectly that will cause some major headaches.
I just changed Plugs and wires on my '01 Tacoma TRD then still had a misfire on cyl 3 so I changed that one coil and she's running perfect. No misfires on the Bullitt but some stuttering. Generally I do Plugs and wires together. Thanks.
Did my Plugs this weekend . followed the excellent write up at Bullitt Archives. Old Plugs looked healthy except gap had grown to .060 (.054 is correct.) Runs great w new Plugs. COPs are fine. Next job, fuel filter.
1 - 5 of 5 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
