Quick thread today. Changing your serpentine belt is easy, but remembering the routing of the belt is tough. So I have included the routing diagram. Print a copy and keep it with your spare belt in the trunk. You have a spare right?
Tools needed: 1/2 ratchet and flat screwdriver.
1. Remove the two clamps holding the "snorkel" between the MAF sensor and the throttle body. Remove PCV line by pinching clip and sliding it off.
2. Wiggle snorkel off MAF sensor, then throttle body, lift and remove whole snorkel assembly.
3. With your 1/2 ratchet, locate tensioner, left of centre, insert ratchet and push down to loosen belt, pull it off the alternator pulley(top centre) and release tension on tensioner and remove ratchet. *Note how belt wraps around lower pulleys, you will have to wiggle around to get it out and get new one in.
4. Install in reverse order, using diagram for correct routing. Using ratchet again, load tensioner until you can slip belt over alternator pulley.
5. Check to make sure belt is in all grooves on all pulleys. Remove ratchet
6. Re-install snorkel
7. Remove all tools
8. Start engine and check to make sure belt is tracking properly. Shazam, you're done. Save diagram, just in case. (For all you route 66ers, bring an extra belt, if you don't need it someone else likely will)
7. Remove all tools
