The only thing to be concerned about is the Nice red/green glowing "Steal Me" sign in your window. I've lost 2 Radar Detectors to the Ol' "Rock Through The Drivers Window" scheme.
I agree that the Detector shouldn't be much of a draw on the battery but I take mine in everynight and put it out of sight when I go anywhere. Gotten burned too many times.
You could also do what I've done.. Just wire your detector directly into the fuse block. A quick and easy way to do this is tie the Ground wire off to a bolt under the dash and wrap the Positive wire around the post of one of your accessory fuses (15-20 amp).. Run the wire up the side and into the window molding and over the back of the dash. Now you've got your wires hidden and you don't need to turn it off. :smile:
Blakwing
2001 DHG Bullitt #171
<font size=-1>[ This Message was edited by: Blakwing on 2001-06-20 17:10 ]</font>
