Not a lot of work recently due to weather. I did take it out for it's first big test drive on Wednesday. I had to take it to the DMV to do a VIN and emissions certification, so that I could get it registered as "Planned Non-Operation". The front suspension was a little squirly, i'm sure that there's a lot of bushings that will eventually need to be replaced.
I finally got to experience was was described to me by my brother as a "miss above 35 mph". Once the car gets up to operating temperature, as you run up through the gears, in 3rd and above once it gets above about 2500 rpm the car just falls flat, no power and you can hear a miss with the engine. I didn't do it until it got to full operating temperature. Not sure what that is yet, it will be interesting to try and troubleshoot that once I'm fully registered and able to run test drives on the road.
The rain cleared up this holiday weekend and I was able to replace the broken wheel stud on the left front. I've never had to replace a wheel stud before, and it was surprisingly easy. I snagged the replacement from the junkyard when I got my headlights.
