My neighbor claims he will be pulling the engine out of his 2007 GT and swapping in a Roush built shortblock. I can get a good deal on his 3V aluminum shortblock.
Question is will the 2001 Bullitt heads bolt on? Will the 3V pistons be a problem with compression/valve clearence? Motor mount issues?
I like the idea for a clean swap,to save 70 lbs. off the front end!
I really dont see a problem. But I could b wrong.
you sure the new stangs are aluminum blocks?
I swore they were still cast iron just like every other GT.
**Googles**
:edit
yup, it is I guess... under 3v info
http://en.wikipedia.org/wiki/Ford_Modular_engine
this intrigues me as this may be something I want to do as well down the road. More importantly I would even love to use the new adapter kit for the 3v heads if the intake will be able to go on as well :)
Administrator
If I were looking at an aluminum engine block replace for an '01, I'd consider the "Aluminator". If you read this MM&FF article, it suggests there are different versions for 2V and 4V heads. If that is true, then one might conclude using the aluminum block from the Roush car would not work.
I don't believe the heads for the 2V and 3V are physically the same dimension.
I don't think they are that much bigger than the 4v, but I could be wrong. It will be an interesting swap. Find some old heads maybe and find out.
It is interchangeable You will have to use our front cover. Main reason why they are called modular engines.
Chad
Administrator
Chad
According to this article, they are called "modular" for another reason -
"Contrary to popular belief, the Modular engine did not get its name from its design or sharing of certain parts among the engine family. Instead, the name was derived from a manufacturing plant protocol, "Modular", where the plant and its tooling could be changed out in a matter of hours to manufacture different versions of the engine family."
