After picking up #3938 in Oct, I started eliminating various engine noises, replacing ignition components/fluids, and chasing a kind of delay in the throttle response at low RPMS.
The whining from the engine was easy enough, replaced several idler and adjuster pulleys and eventually the alternator. The alternator whine was the clutch but I replaced the unit after reading about the reliability of the original alternators. There was a post in another forum that had a link to the design of the clutch and mentioned to replace them at 50k miles.
Ignition tune-up was spark plugs street MSD coils, which returned some lost HP. But still had a tough time feathering the throttle and on some shifts, it felt there was a drop in RPMs although I was still on the pedal.
I also replace the fuel filter and cleaned the TB, but still had that strange flat spot. Read up on the accelerator by wire and tried some reset procedures, no change. Also, replaced the TPS just due to age, but no real change in performance.
When I changed the alternator I had to pull the TB, and that's when I noticed the gunk behind the butterfly. I thought I cleaned all that out from the front but after cleaning the intake side, I can now feather the gas in reverse and there is no drop when letting the clutch out in first or any other gear.
it's possible all these items helped but totally cleaning the TB was the best improvement. I would replace all these items anyway, but it would have nice if I had done that first...
