1 - 12 of 12 Posts
I had no intention of writing about AC, but after Jimbob made a passing remark about getting his AC serviced and the Tech was going to charge him to totally refill the system, I thought I should pass my remarks now on "Earth Day."
First, a little history: Car AC was first used around 1940 in a Packard. It didn't work well but started a trend. By the late 50's, AC was becoming popular and R-12 refrigerant was being widely used. By the late 70's R-12 was confirmed to be a significant factor in Ozone depletion. In 1987 The Montreal Protocol was signed and by the mid 90's production of R-12 was phased out (In developed countries) in favour of R-134A. About 10 years later the Kyoto Protocol went into effect and by 2010 CFC's were being phased out in developing countries. After 2012, European cars no longer were allowed to use R-134A and have switched to HFO-1234yf, which is being phased in here in North America, as I write this. It is currently more pricey than R-134A but will have much less negative affect on the environment, and will come down in price as it's use becomes widespread.
Servicing AC: Service Techs must be licenced to fix AC systems in Canada and the US. It is against the law to release refrigerants to the atmosphere! Period. ( I could lose my licence for doing so) If your AC system is a touch low, the appropriate refrigerant may be added. If there is a leak, the refrigerant left in the system must be captured in a proper AC service unit, where oil and contaminants are filtered. That refrigerant is weighed and held for reuse. The leak must be found and fixed, usually by the use of fluorescent dies and pressurizing the system with Nitrogen. After a successful repair, the system is vacumned down for 30 minutes or so and the recovered refrigerant is reused along with the proper amount of oil, and any extra refrigerant required to get the right total weight. A tag must be attached to the system indicating the repair, date and Tech signature. Ford adds the bright die at the factory so you can detect leaks before your compressor gets "pooched." Others may as well.
One of my pet peeves is the sale of cans of "top up" refrigerant like "Red Tech or Dura Cool." This stuff is not the proper refrigerant! It is "HC-12-A" which is a nice way of saying it's mostly Propane and Iso Butane. I've even seen videos showing how to charge your AC with pure Propane! Don't !!
If you have an old car in the US with R-12, a pro AC guy will have the proper equipment to service or convert it to R-134A. Recently learned that R-12 refills are not allowed in Canada anymore.
We used to keep an older AC service unit just for R-12 repairs. The problem now is that R-12 is hard to find , produced offshore and may contain bad things.
So, take your car to an AC pro for repairs. If they don't have the proper capture and reuse equipment, I suggest you go elsewhere. They should have a dedicated AC repair system and not be refilling from small cans.
A few years ago I worked at a Goodyear Store part time. They had great equipment and training. We had a customer come in for AC repairs because it snowed inside the car when the AC was on. He had added 3 cans of "top up" and the operating pressures were so high it overwhelmed the expansion valve and the evaporator frosted over. The repair included a new compressor, condenser, dryer unit and expansion valve. Total, over $1000.
It's Earth day? I'm celebrating by spraying weeds & brush. Weedmaster for the lawn weeds. Crossbow/Roundup mix for the brushy stuff and the damned English Ivy, and roundup along the fences. When I get done with that, I might just get out the chainsaw and fall a fir tree or two...just for the hell of it. Taking a break right now...hopefully only one 2 gal tank of roundup and I'll be done. Better living through chemistry! Death from above for the weeds!
So, the air conditioning in our '09 Mustangs is going to kill the planet? Some days I think maybe it is time for that big asteroid to hit...maybe the next critter to be head of the food chain will do better than humans did.
Seriously, thanks for the tips you give here...
BTW if you have a home AC unit, R-22 is being discontinued in 2020 (Jan 1) Suggest you get your home unit serviced before an upgrade to a new refrigerant is required. Once the R-22 inventory is gone then...Especially you Florida and Texas folks. No new units with R-22 have been available since 2010.
So, if one uses top up cans, the moron is putting compressed explosive gases in a leaking system around a high heat source?
Sounds like Darwinism.
Mechanical A/C was invented in 1842, Florida physician John Gorrie in Apalachicola FL to cool malaria patients. It used ammonia.
Apalachicola is now known for excellent oysters.
· Car Whisperer
another great article. thanx Pat!!! this one definitely needs to be a part of the sticky group.
Reactions: bullit4404
Ammonia systems were used in Canada for years to freeze ice in indoor skating rinks. There is some promising work being done to use liquid CO2 for cooling systems, which would be cheap and not a significant Global warming issue.
Enjoy the oysters, I'm allergic.
Valuable Lesson Learned. Do not trust those little gauges on those "top off" cans. Wifey car was not cooling as well after 6 - 7 years so I got one of those cans with the little gauge. The gauge showed low pressure so I started putting in some Freon based upon the gauge. Pressure just didn't seem to increase. Eventually, the compressor started cycling off and on so I knew something was not correct. I let out some of the pressure (don't ask how I did it) until the compressor ran more or less normal. Took the car to the dealership and had them check it out. As I guessed, too much Freon (134-A). What I learned, if you don't have the proper gauges, don't do it. The gauges on the cans are not reliable.
· Car Whisperer
had a similar experience Jack with my own car. charged it up, gauge on the charging system put it in range. took to a friend who does a/c work as a part of his general auto stuff, threw his gauges on it and it was way off. often things that seem to be good to be true, are not. lesson learned.
Discussion Starter · #12 ·
Those little top up cans are just skirting the law. Because they are Hydrocarbons, they don't come under the CFC laws. But, you get an evaporator leak to the interior, and that stuff is heavier than air, open your door and the door switch sparks. Like lighting a BBQ after the gas has been on for a few seconds. R-134A is flammable but at nearly 300 degrees higher.
Just trying to keep you guys from burning your eyebrows off!
1 - 12 of 12 Posts
