1 - 12 of 12 Posts
Looks like a good deal. These are $30 each at Jegs.
RPMOutlet has them for slightly cheaper.
Now do these Accels come with the connector boot and wire? The stock ones suck. Or dou you have to buy the Granatelli connectors to go with these?
So to get the full advantage out of these you need to eliminate the factory spring type connector wire in the stock plug boot by installing these for $125.
So lets see what summs total would be for a good upgraded coil pack set.
Accel coil packs = 24.95each x 8 = basically $200
Granatelli COP connectors = $125
So $125 + $200 = 325 + shipping for the upgraded coils.
If stock they will not increase performance. Great replacements for OEM if they are bad. If you have supercharged or using nitros and want the increased performance, you are better off with the Kenney Bell Boost-a-Spark.
You do not have to buy the better boots from what I've been told. I just bought the Accels from RPMOutlet for $22.95 each.
At that price you might as well upgrade to the MSD cop's, seems like theyd be your best bang for the buck. Summit lists them for $48/coil ouch!
1 - 12 of 12 Posts
