Does anyone know where the drain for the AC coil in the temperature blending box empties under the car? I have run the AC a couple of time but have not seen any condensate puddles under the car. The coil is in a plenum box that is on top of the transmission hump just inside the fire wall. I can't see the bottom of the box because it sits on the hump itself and I haven't crawled under the car to see if it has a hose or if it just drains directly onto the top of the transmission housing. The service manual talks about checking the drain to make sure it's open to prevent mold but it doesn't say where the drain is.
