OK, here's the deal. AC is charged and not losing any freon. Runs about 20-30 minutes fine, then quits, don't start cooling again until it is turned off for about 10 minutes or so, then starts cooling for about 20-30 minutes , then cycle starts again. Any thoughts?
Do our cars have a condenser? If so, it sounds like it may be freezing up. I know my truck did that and it was the condenser. Ran fine for about 20 minutes then would blow warm. Also never lost freon and was fully charged, so sounds like that may be your problem. Good luck.
How do the pressures look on a manifold gauge set when the AC system stops working?? Maybe building excessive pressure because of a slight restriction and the high pressure switch is shutting the system off? But I'm probably thinking to much into it.. :)
