1 - 4 of 4 Posts
Hi,
I have a 2008 Bullitt and I'm having problems with the Air Vents only going through the Defrost Vents. I was told it could be an issue with a disconnected or broken vacuum line. I installed a radio a while ago and it could have knocked the vacuum off. I was told it was probably at the Vent Actuator. Does anyone know where the Actuator is located? Or has someone had the same problem as me? I've searched everywhere and I can't find anything on Google. I love this car but I can't afford to take it to a shop right now.
Thanks!
Patrick
You might get better visibility if this was posted in the 2008 Mechanical Section of the forum.
Contact one of the administrators and ask them to move it for you.
I've had this same problem twice already in my 09 B, for me it was just the actuators that were the issue, two different locations. The way I could tell is because I would also hear a loud clicking noise when changing the positions on the air vents using the knob.
Here's some videos I used that might help you out.
Hi,
Thanks!
Patrick
I remember having to same issue with my 2008 Bullitt. I don't recall what the dealer fix was, but sounds like maybe this is another one of those Bullitt specific problems.
1 - 4 of 4 Posts
