FlaFyrman said:
Seems the rotors would prematurely wear thinner faster than normal?
This is by design actually, but the rust itself is not necessarily a wear factor.
Since pad material is harder post asbestos days, rotor metallurgy has also
changed to be softer and more ferrous (read pig iron) in the alloy. Americans do not like the inherent disc brake squeal. Generically speaking, harder pads = softer rotors to remove squeal, which also = faster rotor wear rates, higher incidence of warpage, and faster rusting....
The surface rust is not a wear issue however, one swipe of the pads and the rust is gone.
Cryo treated rotors are not necessarily any less prone to this.
All Cryo does is immerse in L-nitrogen to create a denser alloy crystal.
With the crappy alloys out there, there is greater chance of impurities creating
stress cracks etc....cryo helps to reduce this risk (interesting, even though cryo processes generally make metals more brittle). But, the basic alloy is the same....where there is free iron...there will be rust.
