Typically straight line traction will be worst than with 17s. Even though your tire will be wider with a 9.5 wide rim the tire will have a shorter sidewall and not be able to absorb the shock of dropping the clutch. Improved grip even on a road course is debatable with larger daimeter rims, generally what is preferred is the smallest diameter rim to clear the brakes. This reduces rotational mass and allows the largest sidewall to absorb bumps better.
On another note, 18s look very pimp. I loved the look on my Saleen, but gave up some performance for them. At the strip my best times were with a set of 15inch stockers with drag radials on there.
Hope that helps.
