I was hopeing someone on here had a part number or size that I need for my novi 2000.
Really dont want to spend the 80 bucks from paxton when I know the part store probley has the same belt for half that. Any help would be great.
Get a some string and use it to route your belt then mesure the outcome. You will probably have to have a friend help you with the tensioner belt.
I wish it was as easy as looking at the belt for the part#. I am intalling the blower, all I have is the stock belt. Would your vortech belt be the same for my Novi 2000? I believe they use the same bracket. If so what size belt do you use?
Reload has a belt length of 108". A 106.5" belt was referenced in the link above. I would look for a belt length in between these and then if it is too short or too long, take it back and get one an inch bigger or smaller.
Goodyear part# 4061073 (6PK2725), 107.3" length, 6 rib
Gates part# K061073 (85522335), 107.3" length, 6 rib
Dayco part# 5061065 (6PK2705), 107" length, 6 rib
Discussion Starter · #10 ·
Paxton wont tell becauce if they told me then I wouldnt buy there 80 dollar belt.
This is wierd I went and got the exact belt that was on reload got the same part numer in the pic. Its to small. With the Tensioner maxed out I could just barley not get in on. should I go one or two inches bigger?
