Not needed, as the Bullitt is using solid lines mounted to the solid rear axle housing. If the Bullitt had IRS, then, yes, braided steel lines would be available.
Actually I believe there are two flex lines that run over the axle on the rear.
I was already to order a set for the front and rear and after a little research decided not to use them.
I beleive there should be at least one flex line running to the rear axle. It maybee a solid axle but there are still springs between the axle and the car.
1 - 5 of 5 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
