1 - 20 of 23 Posts
Anyone else dissapointed by the poor performance of their brakes? My wife's '98 GT stops better.
The Bullit has 2 modes of stopping:
1. ABS on
2. Barely stop
anything in the middle reverts to braking method #!, and the ABS is on. What a joke!
I used to have Baer
s on my '90 and expectred similar performance from the Bullitt. My mistake.
I'll add it to the list of issues for the dealer to look at.
I owned a 98 GT mustang for 3 years and had almost 40k before trading herin on the BULLITT and while I enjoyed her I have to say
the brakes were in no way comparable to the bullitts, they faded ...took longer to stop, pedal pressure etc etc...I had her in on 4 seperate occasions for issues the dealer said were common.
I have experienced no brake issues what so ever with my BULLITT maybe there are specific brake issues with your particular bullitt...take her in to the dealer and check it out
I also have no complaints on braking on my Bullitt. Actually, I think it brakes very well.
I agree that the brakes on this car are the best factory ones I’ve seen. There must be a problem with your braking system that needs repair. It should be number 1 on your list of repair items!
Lee50..
I ran an autocross a few months ago to get a baseline on the car and the brakes performed very well. We had the same brake/caliper setup on our '95 Cobra R and Pontiac Firebird in IMAS and they worked fine. You either have a hydraulic problem or a pad problem.
Brian
Discussion Starter · #8 ·
There's definitely some kind of issue there.
I have about 4 issues to take it in for now, I'll just add it to the list.
The rear brakes also make ungodly amounts of noise when it's wet/damp out.
I bought a set of MM braided front lines, but I'm going to wait and put them on after the dealer has a look at it.
If there were a difference in braking, it could be attributed to the Bullitt being so much heavier than the GT. However, the larger breaks on the Bullitt should make up for the added weight...and then some.
No complaints here though. I got into the car pretty hard last Thursday for the first time. During the run DHG1935 took a racing line around a two-lane 90 degree turn from 85MPH to 35MPG like a champ.
lee50guru,
Check out the pics of my Baer Racing rotors in the Mods forum. It's subject heading is
EradiSpeed Rotors. These were a direct replacement and I am using the OE pads(as per Baer Racing suggestion). They sure make a difference with fade issues.
Brad
Sorry,
Glazed has got me thinkin about doughnuts :smile:! LOL. My Fronts sqweek quite a bit, but these ARE Cobra brakes and mine are very good also. Couple of magazine tests show both the Cobra AND Bullitt same braking distances.
Having owned a 2001 GT before taking delivery of my Bullitt, I notice a great deal of braking improvement on my Bullitt. The Bullitt has saved me from rear ending someone a couple of times and I was amazed that I did not hit the car in front of me that was making a panic stop.
BEST BULLITT Nats 06
Same here Teddy! Hubby was getting on a freeway ramp and some lady was STOPPED waiting for traffic to clear and Bill had to stomp on the brakes and missed hitting her. The only thing he could say was "Stupid b**ch!" of course, and "Glad we have these Cobra brakes, man!" Saved our asses too! :smile:
No complaint at all with my brakes, in fact, I am amazed out how well it stops up to this point, 770 miles on the clock.
:bullitt:
I've had DHG #294 since mid May. I ordered it on January 23rd. This is my second Mustang, the first being a 1995 GTS that I bought brand new back in 95. The brakes on that car truly sucked. At 15K miles the dealer re-surfaced the rotors and replaced the pads at no charge. At 30K miles (still under warranty) they replaced the both the rotors and pads. Needless to say at 55K miles the brakes were again toast. Since I would be paying for this setup, I upgraded to a nice set of Brembos. All that being said, the brakes on the Buliit are unreal. I am more concerned with being rear ended than with hitting someone else. Its not just the stopping distances, but the repeatability. These things do not heat up.
Discussion Starter · #19 ·
What I've really noticed is that the first 1/2" of travel of the brake pedal does nothing. This would be the area in any other car where light braking takes places.
Stopping in normal traffic from 25 either results in the "why am I not stopping" syndrome follwed by the not-so-pleasant pulsations of the ABS on my foot.
#2580 - back to the dealer for 8 different issues.
what kinda pads should we be using when we need to replace the brakes?
Are the pads made by brembo or just the calipers?
1 - 20 of 23 Posts
