1 - 12 of 12 Posts
I am in need of some new brake rotors. I would like to upgrade from stock, anyone have any suggestions?
I have Brembo Sport slotted rotors(p/n 47005) on 2135. The Tire Rack has them for $280 pr. or you could go with the Brembo replacement rotors(p/n 27005/67005) for $124 pr. Both are excellent upgrade rotors. Don't forget to get new pads also. I like the Hawk HPS for the street.
I like driving on open track days at the local road course. I decided on PowerSlot Cryo rotors.
Very satisfied.
On Scott Hoag's recommendation I also chose Performance Friction pads which are available from Auto Zone.
Even on open track days, the stock Bullitt/Cobra calipers are all you need.
DHG #1078 said:
+1 for hawk pads
-1 for hawk pads
they rattle.. I've posted like 50 other times on it... but they loosen up in the caliper. I will go back to Motorcraft and never use them again.
Ezekial said:
-1 for hawk pads
Did you use the little spring clips that keep the pads from rattling?
I used whatever it came with.
problem is those expanding cups that are riveted to the back of the pad, and then "lock" into place in the caliper comes loose, thus causing the pad to rattle in the caliper. I ended up putting some gasket stuff behind the pad to help it stick to the caliper and not rattle.
Ezekial said:
-1 for hawk pads
Have never experienced that problem. Nor heard that from anyone else who I know using Hawk pads.
I've heard two others that I know of
I put HP+ on for the end of the summer, maybe 200 miles on them. After I put the B in hibernation and checked things out I discovered maybe I should change the rotors. Will there be any problems putting new Powerslots on with the HP+ pads? Should I change to Powerslots on all 4?
1 - 12 of 12 Posts
