1 - 12 of 12 Posts
Depending on the miles of your car, possible warped front rotors. Ford is notorious for that.
That could still be an issue, especially if you brake hard at 120 mph on a regular basis. I didn't look, I was thinking 01 Bullitt. It may also have something to do with the ABS?
Probably warped rotors, a common problem with the rotors of today. May be covered under warranty.
Mike in Spain said:
On braking at speed at around 120 mph I get a lot of vibration and movement through the steering wheel, has anyone experienced this problem before,what could be the reason ?
I have killed 3 sets of disc rotors and 4 sets of pads in 10,000 miles
I got on it hard at just over 150 racing a VR6. That killed a set of discs in one go and they ended up
with Blue spots all arond them.
Just change out the discs and pads to start. I have done so many now that a custom Race Company
is going to make me some custom 2 part disc rotors-
Look out for this big brake mod
there is already a few companies making these
quick example
http://www.steeda.com/products/dba_brake_rotors.php
1 - 12 of 12 Posts
