Hello all 'lucky' Bullitt owners...
I just registered to post on this bbs for perhaps just a little help from an actual Bullitt owner and/or anyone with contacts with Ford (Bullitt parts) to help me with my challenge.
You see, I'm unfortunately NOT a lucky Bullitt owner (wish I could afford one... :sad: --but I can't), but I actually own a T-Bird w/ a '96 Romeo 4.6L soon to have '01 Romeo PI-heads slapped on, -and I've went out and bought a complete Bullitt intake set-up as it's overall cost was well below the comparable cost of the FRPP SVO alternatives towards my aspirations for a little more 'ummph' in my Lazy-Boy 'Lead-Sled'.
So, can someone please help verify this item for me?
All I need is the factory OEM part number stamped right on the Bullitt's T-Stat housing (water inlet/water neck housing...whatever your way of calling it may be) -as I've been told it's the same, identical p.n. as on the '96-'98 GT v8 Stangs, the T-Birds and Cougees of the same years, and even matches the 2001 GT Stangs p.n. too? ...
But I've seen pictures of it -against the Ford p.n.# F6ZE-8594-DC (or F6ZZ-8592-C -which is the number on the Ford box the water neck housing uses) that my car has -and evidently the GT STang 2v 4'6Ls, and I'm near certain they are "NOT" the same.
The Bullitt's water neck seems to angle more straight-out (with a kinda upward sweep), or even a bit towards the driver's side of the intake manifold, while all these other T-Stat housings are more parallel to the intake's T-Stat housing port and they also turn slight;y towards the alternator (-all when bolted up of course...)
Can anyone take a peek under their hood and confirm the Bullitt's water neck aluminum inlet housing stamped p.n. for me?... It would really help. :grin:
I also "know" that the Bullitt's upper radiator hose has a different bend and angular shape than that of the other 2v 4.6L applications (i.e. T-Birds, older Stangs, -and don't know but think so -even of that as on the '01 Stangs???....), but as this hose obviously has no 'stamped' p.n. right on it, I'd need someone with a Bullitt parts listing (or access to it...) in order to help me out with this upper hose piece.
Believe me, I've tried the Ford Dealerships, but the ones I've have contact with so far...none have much to go on -with some of these Bullitt p.n.#'s still, -as they're so new and all.
But one thing for sure I do know -if a Bullitt owner ever needs these pieces (upper rad. hose and T-Stat housing, etc.) say from a mechanical failure, wreck, or some other reason.... -and they get the parts I'm getting as x-ref numbers, they won't be happer campers, as there's a thing called an 'alternator' in the way! ....
Anyone willing to help a 'non-Bullitt' owner with this 'owner' specific request for p.n.#'s would be a welcome voice. I figured I can always work around this mod. without the correct parts, -but it's so much better to do it the correct way -if possible.
So -that's why I posted here...what better place than to ask the Pro's (those who have keys to actual Bullitts!...)
Thanks in advance for any helpers out there.
DreamCatcher
DreamCatcher
