cam install.....
998 Views 12 Replies 7 Participants Last post by  Bullitt 736
hello to all fellow bullitt heads my name is juan im new hear and i just recently baught an 08 left over bullitt DHG im currently thinking of doing a cam swap and have experience doing so but on my 2001 bullitt i was hoping some one here can lead me in the right direction as far as were to get a detailed description on how to perform the swap thanks to all in advance.
1 - 13 of 13 Posts
Dang if only I had taken the time to do what I said I was going to do, I would send you to the 08/09 archive for my write up. I guess I have something on my to do list. I have to take care of some family stuff tomorrow but I will actually do the cam install write up Thursday.
If you have any specific questions ask away, always happy to share what little knowledge I have!:lol:
EDIT: if you did it on an 01 the 08 will be easy!
thanks for the quick response and for your generouse offer i will definetely let you know if i come across any issues or have any questions, which brings me to my first one....lol....did you use any special tools to keep the tension on the timming chain? this is really my only main concern also what cams do you have? or reccommend i was originally going to use thumprs but ive heard from a variety of people that you loose low end torque?
We have the FRPP Rod Cams. They do not require the phase limiters. As for the timing chain, he didn't use the wedge tool but did come up with a pretty crafty way of keeping the timing right. Here's the post for now though. (We are PX junior too.)
http://www.imboc.com/forums/showthread.php?t=169551
Dang I started looking and I can't find my pictures right now. I did take the front cover off, I could have done the job without it but I wanted to MAKE SURE the chains didn't slip off the crank and the best way for me to do that was to be able to see them. I set the crank key way between the 9 and 10 o'clock position and then tweaked it back and forth till I had the least amount of valve spring tension on the cam then, one chain at a time I use (safety wire) to tie the chain tightly in place! marked the cam sprocket to the chain in (overkill) 5 different spots! LOL break the sprocket and phaser loose then slowly a little at a time loosen the cam caps until all the valve spring tension is gone, finish pulling the sprocket and then reverse the procedure. The cam followers are a pain to keep in place but not too bad. Again taking the front cover off was not absolutely needed but with only 7,000 on the clock I wanted to make DANG sure I didn't destroy my engine. To me it was worth the extra work. If you pull the front cover just make sure you number your bolts, I didn't on mine and had to play musical bolts to get them all back in the right spots, next car I did was a Thumper install and I numbered his (man that was easier)
As far as which is better I am about 10 HP behind what he is making (he has a JLT CAI which flows just a LITTLE better than ours does) but he complains about loosing his low end torque and that it affects his driving, I have not had that issue. So for my money I say the FRPP but there are many out there that have the Thumpers also that say it did not affect their drivability, so no help from me on the decision making!
Well After reading Terry's thread and getting a good pay check I pulled the trigger last night...
Ordered the Cams and Delete plates at Brenspeed, thank's Brent great Service like always.
I would also like to thank Terry for putting me on to Brenspeed taking time to talk to them was the best decision for me B they really know there stuff...
does anyone know what the link is to get a new tune from Brenspeed...
I bought our cams from MRT since they had sponsored our first few Bullitt Nationals. They also sent items for my local Spring Show. I prefer to sound of the Hot Rod cams after hearing the different videos online. I like to keep that low Bullitt rumble.
are the hot rod cams agressive idile and if so what are your dyno numbers, hp and torque did you loose any low end power?
I don't understand your question ???
I think I could Help you if maybe you state your question different.........
JC,
If you would like to Hear a Bullitt with the "Thumpr" Comp Cams here is a New Thread.
http://www.imboc.com/forums/showthread.php?t=170743
Hi, question for bluebulllitt. I just had engine failure on a 01 Bullitt and got it overhauled but the engine runs bad like if it was bad timing, (according to some friends who are mechanics). My question is, on what mark do you time the cam to the crank. According to some manuals "Haynes" the round marks on the cam sprocket should be perpendicular to the head when the crank is TDC. Now the machine shop says, "No you place the mark one tooth off clockwise". I'm not a mechanic but a manual is a manual but an engine specialist is a specialist. However I know our heads are different from normal 2001 GT's. Who's right and how do I fix the enormous vibration and lack of power.
Any help on this subject would be of great appreciation!!
is the car miss firing from the sounds of it it may be a bent valve
Not so. They are the same Romeo head as other late 2001 to 2004 GT's.
Can't help with the cam timing question.
1 - 13 of 13 Posts
