Took 1546 into the shop this week because of a new noise that has started. Seems to be originating from the engine (passenger side) toward the shock tower. Car doesn't have to be moving to hear it and it almost sounds like a rattle...not super loud but noticeable.
Mechanic (dealer) told me it was the cam tensioner and that it was a "normal" noise. Nothing to adjust as it's hydraulic.
My question is whether I should push the issue a little harder. The warranty expires in July so if something should be replaced, I want it done prior to the expiration.
Last fall, Ford had to replace most of the engine under warranty so could this be related to the engine repair in any way? The dealer checked compression, etc. and all were good...no metal shavings, etc. either.
Thoughts?
Thoughts?
