1 - 13 of 13 Posts
I just put the 2nd set of new tires on my black '01 Bullitt (no mods), and had the tire shop do a wheel alignment. I was told that the camber was just out of spec and couldn't be brought back into alignment without adding what I think he called a "camber plate" (I might have that wrong). He said that the suspension sags over time, and the camber adjustment is now maxed out.
This is my daily driver with 68k miles, and I am wondering if this seems right. If so, what causes the sag, and is this normal? Could they have been looking at '01 GT alignment specs instead of Bullitt?
Can anyone shed some light on this for me? This is my first car that is more than just basic transportation, so I don't have a lot of experience with this sort of thing.
here are the specs. found them in the Bullitt Archive at top of page:
http://www.bullittarchive.com/7000/7027/2001_Mustang_Specifications.htm
Suspension System General Information
Specifications
Item
LH
RH
Total/Split
Alignment Specifications - Front
Caster
3.2° ± 0.75°
3.2° ± 0.75°
0° ± 0.75°
Camber
-0.50° ± 0.75°
-0.50° ± 0.75°
0° ± 0.75°
Toe (positive value is toe-in, negative value is toe-out)
0.25° ± 0.25°
Alignment Specifications - Rear, Cobra
Caster
Camber
-0.7° ± 0.2°
-0.7° ± 0.2°
0° ± 0.50°
0.25° ± 0.15°
General Specifications
Item
Specification
Dogtracking - maximum
13 mm (0.5 in.)
Clear vision (negative value is counterclockwise)
-2°±3°
Vehicle Ride Height
Front
4mm ± 7.6 mm (0.2 in. ± 0.3 in.)
Rear - GT and Base
128 mm (5 in.)
Rear - Cobra
36.3 mm ± 7.6 mm (1.4 in. ± 0.3 in.)
Ball Joint Radial Play
Lower ball joint - maximum
0.8 mm (1/32 in.)
Vehicle Lean (Side-to-Side Height Differences)
Front - maximum
13 mm (0.5 in.)
Rear - maximum
13 mm (0.5 in.)
Vehicle Attitude (Front-to-Rear Height Difference)
Maximum vehicle attitude
19 mm (0.75 in.)
Torque Specifications
Description
Nm
Lb-Ft
Front suspension camber adjustment plate bolt
40
30
Front suspension camber adjustment plate nuts
40
30
Rear camber adjustment nut
90
66
Toe link jam nuts
55
41
Tie-rod jam nuts
55
41
Thanks, I'll check those numbers with the alignment print out I got to see if it's really out of spec.
But assuming it is, does this stuff about needing a camber plate sound right? Is this something that just happens over time, and has anyone else seen this sort of thing before?
I have always heard that the stock mustang camber plates will align the car to specs with it lowered up to 1 in. One thing to consider the bullitts are already lowered 3/4 in. And I believe they have the same specs as a regular GT. The springs can sag a little after a while. More affected on wore out struts or shocks and driving conditions. At 68k miles would consider it just a break in. I would recommend getting the plates anyways. They are stronger than stock and have more adjustability. I don't beleive the stock plates adjust caster either. Have a buddy who was in your shoes a couple years ago at 30k miles. They supposedly loosened the
k-member bolts and shifted the k-member to get it just within specs. He still claimed that it wasn't right and pulled to much.
Here is a link to the ones I have and recommend: http://www.maximummotorsports.com/i...om/store/index.php?main_page=index&cPath=1_68
I lowered my car, so I put on the m/m plates to get it to spec. something is funny the car cant sag that much and with only 68k. I honestly would check out another align shop.
Dropped the '04 1 1/2" and only drilled out the rivets for all the adjustment I needed. Just an FYI.
Oh and my Bullitt has been lowered another 3/4" from factory and I've just had an alignment as well. They told me mine was out of spec as well but the numbers were so small that there will be no issues. I could use a set of caster/camber plates but right now nothing justifies me spending that cash.
I just lowerd my car also and they said it was just slightly out of spec but not enough to cause a problem.
Charles
I have a set of the Shark UPR's I had powder coated and am waiting to install, they didn't cost all that much. got 'em on e-bay.
Bullitt 736 said:
Try these instead. Much cheaper and should work just fine.
http://www.steeda.com/products/camber_adjust_bolt_set_struts.php
My alignment guy suggested getting the caster/camber plates.
He said something about my passenger side strut(?) tower being higher than the other one. He couldn't bring it into spec.
It looks like my front tires are pointing away from each other slightly. I need to fix this before it ruins my new tires.
1 - 13 of 13 Posts
