BEST BULLITT Nats 06
Hi, I know the "CD error" thing has been brought up many times in the past. I thought someone could chime in here instead of me being lazy and doing searches on here for how to correct it.
Something about inserting a credit card?
pull the fuse on it and that should reset it
No. 27
fuse A 25
Vicki,
Passenger compartment fuse panel:
The fuse panel is located below and to the left of the steering wheel by the brake pedal. Remove the panel cover to access the fuses. To remove a fuse use the fuse puller tool provided on the fuse panel cover.
I used a set of needle nose pliers to remove it. My cd changer went haywire about 11 years ago and I replaced it with another Mach 460 that I bought online. I hooked up an ipod/ihone converter to the back of the unit and ran the cables under the shifter console and up through the center console storage. I have the original look but have the updated music setup.
see pages 133-135 of the owners manual for the fuses.
Jim
Vicki,
Jim
Thanks Jim. I am first going to try inserting a blank CD or a credit card to get out a stuck CD and see if that there works.
pull the fuse and put it right back in. that should eject the CDs. credit card may work if it gets stuck at the top
Let us know if that works. Hope it does
Discussion Starter · #10 ·
Hey Joker, I tried the credit card with the sticky tape attached to it and stuck it in the slot and out came the stuck CD! Thanks for all your appreciated help!
Vicki
glad it worked out that way! the cd players were great for the time.
