Going to replace the stock shifter in my Bullitt on Monday with a Steeda Tri-Ax and figured I just might change the fluid while I'm at it. I know on the T-45 a lot of people recommend the GM Syncromesh (GM part #12345349). Does that also apply to the 3650?
If I go with Mobil 1 or Redline instead, which weight and/or part number should I use? How many quarts does the 3650 hold?
Finally, what is the easiest method of draining the old fluid from the 3650, I haven't been under my car yet to check it out. Your opinions and experience are appreciated.
