I do a lot of bumper to bumper and city driving. Will a chromoly flywheel hold up to the heat without getting hotspots or warping? Thanks for your help.
BULLITT3629 said:
Its supposed to be better the steel or aluminum. Personaly I run Aluminum, I don't know anyone the runs a chrome moly wheel.
I was just curious because one was installed in #801 and I was wondering if it sustained the rigidly and longevity of the steel one. I don't want to have to pull the tranny to replace the flywheel soon. Will it hold up to Rikki Racer? Will it hold up to high heat? Thanks for your help.
Discussion Starter #8 (Edited)
OK, here's the dealio. The throw out bearing had been squeeling like a pig, so I figured with 67,000 miles we should just do the clutch thing. By the time you go in and replace the bearing you might as well shoot the works.
I'm a firm believer in if you find an honest shop it's worth it's weight in gold. The only problem is the shop is 135 miles away. I drop the car off on a Saturday, take the train (kinda expensive but what the hay). So I ride the bike all week with plans of picking up Maggie the following weekend. That's a whole week to "fine tune" things.
Now we ALL know there's not a shop that's 100%.I've been a mechanic all my life and I must admit I screw up from time to time.
I go to pick up Maggie and it takes all of about 10 minutes to realize somethings wrong. There's a vibration at a certain RPM that wasn't there when I dropped her off. I shlept the train back up to LA cause I'm not taking her the way she was.
I find out the company that turned the flywheel screwed up and didn't turn it true. Because it's not generally a good practice to turn it twice (especially Rikki Racer style!) I was offered a chromoly flywheel normally retailing $375.00 for $60.00 with labor.
After reading up on them I discovered they're the bomb for performance. However I don't know how they fair in every day traffic. Because they are lighter do they warp easier, hot spots? I just don't want to make a big mistake, and thought a Bullitt head could help a brrutha out. That's about it. Feel free to flame or offer constructive critisizm. Rock on.
