On 2001-12-04 22:20, BULLITT #1042 (Ray Ackerman) wrote:
Ray Ackerman here, I just received my set, Thanks I have two questions:
I'm asking here because I'm sure others may have the same questions.
1) when I placed my order I said I would like to just use them when I drag race you said that's fine. But in the instructions it says if there not permently affixed don't go over 60MPH. I will definatly go over 60MPH. Will they stay on for the short 1/4 run at about 100MPH?
2) when permently affixed will they discolor? Turn yellow after time?
P.S. For all how is thinking about ordering the pieces are cut to size very NICE!
(Best ET to date 13.73 my Bullitt is stock other then Nitto DR's)
<font size=-1>[ This Message was edited by: BULLITT #1042 (Ray Ackerman) on 2001-12-04 22:22 ]</font>
Hi Ray,
Good to hear from you again!
The only time we suggest staying at a lower speed is when you use the dry application. This method was really intended for the show guys who would pull them off during a show for no deduction of points. They didn’t have the time to let them dry (wet application). They would just slap them back on and go home. They were just interested in protecting the car for the re turn trip.
**We suggest this application:
For a better look and for higher speeds, apply using the wet application (spray with water. Apply then squeegee out the water and air bubbles) Goes on much easier. Once dry, they’re practically invisible!. Plus the wet application has been speed tested over 100 mph! (lab test @ 160mph ).
Because you could hardly notice them , most use this application and just leave them on the car. You can easly take them off when you want.
As far as drag racing, the speed didn’t concern me, if you remember it was the hot flying rubber that did. Our product was intended to protect the paint from flying rocks and road debris while “getting on it” and driving in the streets without changing the look or the aesthetics of the car.
Thanks for the compliment on the Fit and finish..
Great hearing from you.
Give me a jingle tomorrow. 1800 778 9898
Ed
Hi Ed thanks for the tip!! But what about question #2...... :-B
<font size=-1>[ This Message was edited by: Cleartastic on 2001-12-05 00:00 ]</font>
