After all was said and done how much did you guys spend on your Kenne Bell setup?? My plan is to pick up the KB, and a Cobra short block at the same time. I can do the install myself and am looking at spending around 6K. What were y'alls final numbers?
i think the kb is in the 5k range...for what you are wanting to do i could see you spending 8-9k fairly easy. imo if your gonna boost it, go straight for turbos.
I also installed the KB myself. The total cost was $5399 + shipping + $20 for plugs + ~$25 for antifreeze and miscellaneous stuff.
Well worth the $$$$ IMHO...:wink:
Bruce
Not really a turbo fan. Nothing to me is more frustrating than turbo lag.
I dunno where you're getting 8-9k, Kenne Bell kit is around 5500, I can pick up a short block for less than 1K.
youll have 6500 plus tune, gaskets...maybe i should have put it a little over 7k
also a properly set up turbo car will have little to no lag if the right turbos are used...use one too big and maybe you will
where in the HELL are you getting a complete cobra short block for 1K? (assuming this is a terminator 03-04 style block)
shaun
