1 - 3 of 3 Posts
I had a joint bracket bolts came loose on me and the center section was barely hanging on and ripped the boot, grease everywhere. I was thinking about rebuilding it but went with Ford 1 piece aluminum after seeing it. However I believe the joint bearing is pressed in and it’s one time use. Might want to think about going with 1 piece as well. Good luck. 🍀
1 - 3 of 3 Posts
