Ok so I have had trouble with both my windows. My driver side goes slightly off track once it reaches the top. Pretty sure this is just a window regulator issue. My passenger side door would not close right but the window would go up straight and did go crooked. I never could figure out what was wrong. Today when I was jacking up the Bullitt I noticed that someone previous to my ownership had jacked the car buy the tab where the side skirts meet the floorpan. So once I finished working over the brakes and rotating the tires, I pulled off the side skirts and front pieces. I took a pair of pliers and pulled all the tabs vertical, some were smashed inward and some outward. While I had the side skirt off I thought I would see if the door would close properly. NO. The glass still hit the top part of the car too early. I reattached the side skirt and was glad to see that it no longer scrubs when I close the door. So one problem fixed. I started comparing the doors on both side and then BINGO. I realized that the passenger side glass is about a quarter of an inch towards the front of the car. The glass stayed level but was not in the proper location. In fact, when the window is up you can almost stick your finger in through the weatherstriping. So it looks like I will need to go to a body shop and see if I can have both windows adjusted. If not, I will have to replace the window regulators. Does anyone know if there is any adjustment to these things or are the regulators only working or broken? At least I finally know what went wrong.
