First I want to thank all of you Bullittheads for how much I've learned from this site in the last 4+ months since I joined. Now for my question: I've read on several posts of people putting wheel spacers on. What are they and what is the advantage of having them? Thanks in advance.
Hi Tracy,
It's all about show, but the improved cornering is a nice plus. Maximum Motorsports uses them on their road race car for this reason.
In the looks department, my only other option was to buy wider wheels...Too expensive. But I had to get rid of the "Mustang rear-end overbite"
Dennis
Black#5578
SteedaTri-Ax,DensChrgr100mm,MAC highflow "H",FordRcng3.73's & Alum.Drvshft,rear mudgrds,30mm H&R spacers rear whls,AutoLogic chip,MGW shifter & Haney ring
<font size=-1>[ This Message was edited by: Dennis on 2001-12-06 10:52 ]</font>
An addendum question: How much spacer is too dangerous? I know spacers put strain on the bearings, but is there a safe size to go with that will push off the overbite but won't give that "bent axle" look or damage the bearings?
very nice pics Dennis!!!!
Here is a question related to the spacers: When re-installing the wheels, should the lug nuts be torqued?? A friend of mine told me that whenever a wheel and tire is removed, be sure to torque the lug nuts when re-installing. I was telling him that when I removed my front brake rotors (on my Olds Aurora)to have then re-surfaced, 2 weeks later they were pulsating again when I applied the brakes. Since he owns an auto shop (and is a Mustang enthusiast as well), I asked him why the rotors are pulsating already. Well, he said that because I did not torque the lug nuts, un-equal pressure is put on the brake rotors causing them to wear unevenly. He said I should torque the lug nuts on the Bullitt too........anyone heard this before??
Hi Dave,
Regardig wheels and spacers I think the term you're looking for is RETORQUE...Meaning that any time you place a wheel back on the car you should RE-tighten the lugs to whatever tightness floats your boat about 100 miles after the install due to the chance they may have backed out some.
Spacers and wheels should be re-torqued to 95 ft. lbs. in a star pattern.
John
Hey Dennis,
Thanks for the reply. I always do "re-torque" my wheels (especially aluminum), but my buddy was saying to use a torque wrench anytime you put the wheel back on....probably is a good idea anyway. I just never heard that NOT torqueing your wheels would cause the brake rotors to warp.
I repolished #312 with "Mother's Glass Finsh" today, and as I was, I took the wheels off to clean the insides of each. While I did, I placed some 5/16" spacers on the back from "Rally." They look great and have plenty of lug nut space. I burned them earlier, embarassed a few boys, and parked it in the garage with a larger diameter for only $16 dollars!
