Ok since I cant wait untill monday to call KB I thought I might ask here since i know some others have KB superchargers, and might have run into some these issues.
From what I understand if you have a 9psi kit the only thing you need to upgrade to 14 psi is the pully. The tune you get form KB was intended to cover you form 9-14 psi.
Now what if you drop in a new block with 8.5 compression and a lil more stroke? How much will that affect the tune?
The reason I am asking is I am tryen to avoid a dyno tune on a new block. I would rather braek it in easy before I throw it on a dyno and start running it to redline.
