Well, I finally made to the dyno with the water injection and a smaller pulley.
Once there Tery(the dyno operator) swapped out the stock 3.6 inch pulley for a new 3.33 inch one. The first run showed the same FP problem I had before, but we forged on. The car made 10psi at 6K and had hp and tq gains across the graph. You can see exactly where the water injection kicked in too(kinda cool). It was set to come on at 5psi and suprisingly it did.
The pulley alone was good for around 15rwhp uncorrected and the water injection made gains of between 10 and 17 rwhp from 4600-6000. This was with water only, no alcohol this time. I think with a little more playing around there may be more power in there. BTW, the water injection made no difference in A/F ratio at all. The gains appeared to be entirely from the cooling affect.
It was a good day.
It was a good day.
