I bought my car about 3 years ago, and this has been an ongoing issue. I was getting the fast right turn blinker signal which indicated my bulb was out. It's happened on 3 occasions now, and since the sockets were looking very brown and burned, I decided to replace the entire harness for the 4 bulb wiring assembly for the rear passenger side. I did this a couple of weeks ago after I had also pulled the fuse out for the radio because my Shaker 1000 had also started to act up again after I had disconnected the negative terminal on my battery to go on vacation for a month. Upon my return and reconnecting the neg terminal, the Shaker CD changer kept cycling through looking for a CD every time I'd open or shut the door. Apparently there is also no fix for this, so I bought another head unit.
Anyhow, for these past couple of weeks after replacing the wiring harness, the blinkers have been working perfectly. But today I installed a new Kenwood Double Din radio head unit I purchased from Crutchfield. I still haven't reconnected the amp and sufwoofer in the trunk. But tonight when I went out to get some food, my right turn blinker started acting up again and sure enough, when I got out of the car to check it, that one bulb wasn't blinking. Then when I got home and parked my car and checked the signal again, it was working normally this time.
Anybody ever experience this issue or have any idea what the hell is going on? Very frustrating, and I'm wondering if the guy that sold the car to me did so because of some deeper underlying electrical issue. Multiple bulbs and a brand new harness assembly for that passenger tail light, and it looks like it still hasn't been solved.
