1 - 4 of 4 Posts
Just FYI
If someone else has the same problem,
my car started stumbling every now and then, and finally stalled.
It would restart, and stall repeatedly.
The dealer towed it in and found a bad fuel injection wiring harness on the engine itself.
The situation showed up with the break-out box on the computer. the +5v Vref would go away.
New harness did the trick.
sounds similar to mine...see my post in mechanical issues 'UFO experience'. Dealer would only say they couldn't find anything...claimed they checked/cleaned/tightened every ground wire on the vehicle. So far so good...but good to know a potential source if it happens again.
I posted a new message about this, but this sounds exactly like what's happened to me.
My fuel pump has been replaced 3 times already and it appears to be going out again.
When the car does finally die on me, I get the same symptoms that you spoke of. The dealership has told me they just keep getting faulty fuel pumps in, but I'm looking for something else to tell them to look at. I'm tired of being without my Bullitt!
1 - 4 of 4 Posts
