for a complete motor from a salvage yard visit
Car-Part.com--Used Auto Parts Market
yes the block in a F150 is the same as in the bullitt. i will say with 99% certainty ALL 4.6 3V blocks are the same. YES the F150 4.6 3V motors has a alloy block. the crank, rods and even the heads are the same. the pistons are probably different compression ratios. the CAMS and springs will be different in the heads. the intake manifold, oil pan, and front timing cover will also be different.
as i posted earlier you can also use a 4.6 alloy block from the SN95 mustangs also, this is what i used. the front timing cover mount surfaces are slightly different so if it's not properly sealed you can get oil leaks.
you can also use the block out of a Lincoln Mark VIII. the famous Teksid block is slightly stronger than the the 3V block but not by much. anything under 1500 hp you shouldn't worry about strength differences.
you can also use a 4.6 iron block. the 3V parts will bolt on no problem. it will just weigh more than a alloy block.
NA the coyote block is a pretty solid motor. one thing to keep in mind is this mod WON'T BE CHEAP to do. you can probably pick up close to 100hp by installing one over the 3V motor. you will have to do a fair amount of wiring mods to install one in a S197 bullitt. i would assume a new engine wiring harness and ECU should get you most of what you need.
it will bolt in without problems. i never installed one in a S197 but i would assume you will need the coyote mounts to install it in place of a 3V motor.
this is a common mod so a google search should give you almost all of the answers you need.
