1 - 4 of 4 Posts
Took the Bullitt to the track tonight for the first time, made three passes. I'm pretty happy with the outcome being my first time and all. I know I can do way better, so what does everyone think I can do to improve??
Mods: Vortech V2, no cooler. 347rwhp/351rwtq.
SLP LT's, Off-Road X, and LM 1. MGW Shifter. 3.73 gears
MT ET Streets
First run: (Cooled down, just dusted off the tires. Launched of the two step @ 3.5K)
R/T........... .587
60'............ 1.914
330........... 5.641
1/8........... 8.613
MPH.......... 86.66
1000......... 11.117
1/4........... 13.251
MPH.......... 105.56
Second Run: (Few mins cool down, No burnout cause I was racing my friend with worn street tires on his GTO and wanted to even the playing field. Same Launch @ 3.5K)
R/T........... .089
60'............ 2.064
330........... 5.681
MPH.......... 87.31
1000......... 11.106
1/4........... 13.232
MPH.......... 105.80
GTO is an auto with 400rwhp, no stall, ran 13.439 @106.23
Third Run: (Zero cool down, dusted the tires again, launched at 3.5k)
R/T........... .114
60'............ 2.003
330........... 5.612
1/8........... 8.564
MPH.......... 85.44
1000......... 11.076
1/4........... 13.223
MPH.......... 105.71
You did better than I did and my car has the aftercooler. Your 60' times are consistantly .5 seconds better than mine. Maybe you tutor me next time :lol: . Seriously-nice runs. I'll be going again in the fall. I'll give you a heads up next time, maybe we can meet there.....John R
As far as what yo can improve on-given my times when I went I am in no way qualified to answer that.
ur mph seems off to me 350ish whp should mph in the 110-112 range. are you on et streets or their drag radial....either way just do a nice burnout get them nice and warm and launch around 4000. 1.7 60' and ur in the 12s. what was the weather like humidity, temp, also what is the sea level there? i would just expect that kind of power running 12.50s or better. 1.7 60fts with 300whp and 4.10s can run 12.60-12.50 consistantly on drag radials. just work on getting your 60ft down and possibly check ur plugs make sure the gap is still good on them
Hi
With ET streets at about 11 1/2 lbs air launch hard should get 1.7 60' times. I launch at 5500 rpm
Good Luck
Jim
1 - 4 of 4 Posts
