1 - 4 of 4 Posts
While installing my Mach 1 grill delete, I was attaching the last two plastic fittings that hold the top of the bumper cover on (these also hold the bottom part of the grill delete kit on). I noticed when the fittings were out, the bumper cover moves up and down an awful lot! It doesn't seem there's much support for the bumper when only those two small plastic fittings hold the cover on at the top! Am I missing something here? Where else is the cover supported or held on? Thanks!!
If I remember right you have the 2 push pins up top, a phillips head screw in each wheel well and on each side there are 2 bolts attached to the bumper cover that go thru the fender and have 2 nuts attached to them. That is about it. Someone tell me if I missed anything.
I thought there were four more plastic screws or push pins that run under the front? Other than that, I think that was it. But I do think that even the stock setup was rather flimsy...
1 - 4 of 4 Posts
