On 2001-11-27 23:52, evil428 wrote:
Steve, thanks for your input on the subject. I've been toying with the idea of adding a strut tower brace just for the enhanced grip gained by the reduction in body flex. I like our Bullitts pretty much as they are from Ford, and I'd really love a slightly tighter chassis...but without the inherent increases in understeer associated with the beefier sway bars.
Coming from a '99 Cobra convertible, I was disappointed by how chassis flex and cowl shake there was on that car. And that was just with regular street driving---no racing or autocrossing. Maybe I'm looking for too much tightness right off the shelf from Ford this time around in our Bullitt?
Thanks again!
That is very common on convertibles and attempts to fix it are why verts usually weigh more than hard tops.
For an analogy, or experiment, take a cardboard box with an open top and compare it to one with a taped shut top. Major difference in rigidity.
If I can ever get clearance from the tower... here is what I would do for the Bullitt:
1. Add a panhard bar to the rear. Maximum Motorsports claims that the rear end has been measured moving up to 2 inches. This is HUGE! Of course this would require a different rear anti-roll bar at the same time as previously mentioned.
2. Might add offset steering rack bushings. These things are just cheap! I would want to take some measurements first, but given that our cars are factory lowered they probably need offsets. I expect these would reduce bump steer, another of those things that contribute to a loose feel.
3. Add a triangulated front strut brace that ties into the firewall. I expect the difference here to be much subtler. I probably would not be able to tell a difference in cornering. But triangulation of structure is always a good thing and good strut braces give you this. I expect that this would eliminate the little squeak I have now from up behind the dash.
That is pretty much it for a street car. The springs and such are already pretty stiff for general daily street driving in my opinion. You could spend a lot more, there are certainly enough goodies available for these cars to spend money on. And you could get just that extra little bit out. But auto design is always a tradeoff. And for me, this pretty much optimizes the tradeoffs for cost vs. benefit and relative performance vs. daily utility.
Now if I really wanted to have fun, I would transplant the Cobra IRS under the Bullitt. Better geometry, wider wheel track (like the spacers folks are installing), and much less unsprung weight. Sure you might have some wheel hop in 1st gear but I don't spend much time in 1st compared to all of the other gears.
Steve
