1 - 13 of 13 Posts
Nice job mike! You can use a dab of 5 min epoxy on the connectors. Then just break it off with a screwdriver if you need to remove. Sounds good!
Oh, I'd install a catch can on the car to reduce crankcase vapors. Good luck.
Thanks Brother, I will try that.
Mike
I thought of that the moment I filmed it. Good idea.
Mike
Here it is with all the dress-up back on.
78493
78494
Reactions: bullit4404
NIce work!!! was the expense and labor worth the results?
Discussion Starter #8
Likely not , but we all know that, I am sure.
The only Dyno in our town charges $500.00.
wow, that's high.
A stopwatch is a good "dyno." Do you have a baseline 0-60 time?
I do not. HP really is not important to me but like all the Ford parts on it.
Mike
As long as you like the readings on the "fun dyno," that's all that matters!
1 - 13 of 13 Posts
