First the suspension. What a terrific combination. The overall drop is about 1.5 in the front and about 3/4 on the rear. The front sway bar is adjustable to 3 positions and I set mine to the middle firmness. No camber bolts were needed. The final alignment numbers without the kit are within spec at -1 degree each side, perfect! I could use bolts and get to the max -1.5 degrees but don't want the additional tire wear. I called FRPP and they told be no bolts would be needed. They also said that the rear drop would not enough to warrant an adjustable panhard bar - wrong. With only 3/4 of a drop the rear axle shifted over about 1/4 inch. Probably not enough to cause handling issues but enough that since I know about it and I can see it...it will have to be corrected. Adjustable panhard bar is on order...The quality of this kit is second to none - install was a snap - I really want to add the SVT LCAs now, the factory stamped ones look whimpy compared to the new sway bar and CNC links that are now in place. The ride quality is superb. The combination allows for a very comfortable ride but zero - and I mean zero - body roll with agressively cornering. The only thing holding this car back from AutoX right now is the tires. If you are not a career autocrosser you would never need anything more. I can't wait for a track day at miller motor sports park to make a few runs. I could not be happier with this product, worth every penny.
GTA muffler install. Similar comments as above. High quality product - simple install. The exhaust note is deeper and throatier at idle, High RPM sounds similar to the Bullitt Mufflers. The 4 ich tips fill the bumper perfectly and they were simple to mount and get centered, required loosening the connection at the H pipe to get the right side perfect but the left was plug and play so to speak. The note is satisfying to me and I will not be changing the H pipe like I previously feared.
SCT Bamachips - per Doug shipped yesterday - no report for this Mod yet but will give my feelings as soon as it get here.
Next up CDC classic billet grills (black), my anniversay present from the wife
. Cams and a custom dyno tune within a couple weeks and in the not so distant future a charger...
Until next time - Happy modding
