OK, I see that people are finding fixes now for the pinging from 87 fuel. My solution as others was to simply use a higher rated octane. I just want know if the 92 octane I am using will eventually cause problems within my car.
Thanks all
Aaron #0685
Question Karl, What altitude are you at? and do they oxygenate (spike the gasoline with methanol) the fuel there in ID?
When I had 4165 in CO, in Denver, I could'nt run the winter (oxygenated) 87, I had to use 91. However, I could use the summer brew 87. I could run 85 any time in the mountains (they don't spike the fuel off of the front range).
Personally, I believe oxygenating the fuel drives the cost of gas up more than it reduces emissions. I was an emissions mechanic in Ft. Collins on college and ran many tests for my own edification when business was slow. The only time I saw emissions reduced was after a cold start, before the cats lit off. Granted, I was using just a tailpipe sniffer and not a dyno, but still...
My '89 2.5 Turbo/5spd. Le Baron kicked butt in the CO mountains. Bullitt did great as well. The only pinging problems I had were with the winter 87 down in Denver. I made the Denver-Aspen trip couple of times in the Bullitt before moving to FL that one starts at good 'ol 5280 , goes over a ~10.5K pass and through the Eisenhower tunnel at like ~11.5K. Ran great, on 85 even.
Chris Pedersen
100mm Densecharger
Steeda HD Upper Rear Control Arms
More to come.....
<font size=-1>[ This Message was edited by: cpeders on 2002-03-08 10:24 ]</font>
When I bought the Bullitt, my salesman said that he filled the tank up with Super (92 octane) so I filled her up with super for about a month. Read the manual and immediately switched to regular (87 octane). Nothing changed as far as performance and have not experienced any problems.
I notice you have a low numbered Bullitt. The timing profile in the computer of early cars was slightly more agressive than later numbered cars. There was a TSB out about this and the dealer can reflash the computer to load the later version timiing profile. I have not had this done, I just run higher octane fuel to prevent detonation.
Thanks for the helpful tips. I have already had the reflash if that is what your referring to Peo'r. To be honest, I don't think that had any effect on my vehicle at all. Oh well, as long as it does not hurt anything I guess I'll keep buying the 92 stuff.
Thanks
A-
