1 - 13 of 13 Posts
Possibly looking to part ways with my 2009 Bullitt Mustang.
The car is fitted with a production 5.4L V8 engine from a Shelby GT500. This car has been tastefully modified completely inside and out using nothing but quality parts. Every part added to the car has been cataloged as well for records. I will be supplying the new owner with all records as well as the Ford certificates and paperwork. Original window sticker, copy of invoice, both sets of keys, etc. are included with sale.
Internally the car is a GT500, everything from the PCM to the complete body harness is from a GT500. It’s just to the naked eye, the car is a complete sleeper and looks like a stock 2009 Bullitt and is registered as such.
The car has right around 25K miles on the chassis. The engine only has ~1500 miles on it. I bought it as a fully rebuilt 5.4L from BilletProShop. The engine runs very strong.
It is a 1-owner car and records are available for it. I bought the car in December 2009.
Vehicle Specifications
Engine
5.4L 4V GT500 Engine w/ 1.9L Eaton Toots Supercharger
2.5” BPS Pulley on a Gates Heavy Duty Belt
FRPP 65mm Polished Throttle Body
FRPP 113mm CAI
C&R Heat Exchanger w/ Roush Expanded Coolant Tank
2013 GT500 Fan Shroud
2010 GT500 Radiator
Reische 170* Thermostat
MRT O/R H Pipe and Borla Touring Mufflers
The car is tuned by Lund Racing.
Transmission
TR6060 6-Speed Manual from a GT500
2012 GT500 Flywheel
2012 GT500 Slave Cylinder
2012 GT500 Clutch
MGW Short Throw Shifter with a custom ‘Hurst’ lever and knob
2013 GT500 OEM Carbon Fiber Driveshaft Retrofitted
BMR Driveshaft Loop
FRPP Stainless Steel Clutch Line
FRPP Rear Axle Differential Cover
Suspension
Koni Yellow Struts and Shocks
FRPP L Springs
Maximum Motorsports Adjustable Camber Plates
2011+ Mustang Swaybar Endlinks and Bolts
FRPP Front and Rear Sway Bars
BMR Billet Lower Control Arms and Relocation Brackets
BMR Adjustable Upper Control Arm and Mount
BMR Adjustable Panhard Bar and Mount
BMR K-Member
GT500 Front Lower Control Arms
GT500 Front Brembo Brakes
Stainless Steel Braided Brake Lines
Billet 7/8” Spacers on all corners
255/45/18 Continental Extreme Contact Tires on all corners - I planned on widening the rear wheels, but haven't gotten around to it.
Various additional items have been added throughout the car too:
*Custom ‘zPod’ Overhead Gauge Pod that houses two Aeroforce OBDII Gauges (Wideband and Boost Sensors hooked up too)
*Entire car has been fitted with Dynamat Sound Deadening
*OEM HID Headlights have been fitted to the car and they are 100% functional
*Entire car has been repainted professionally using BASF paint and high-grade clear-coat which is much stronger than factory paint. The front antenna hole has been filled in, both washer nozzles and the rear sat antenna on the trunk. This was just done in Fall 2014.
Car has been in one accident – September 2012. It was a minor 1 car accident where I had to swerve around a stopped car and put the driver front wheel into a curb. Wheel, tire, lower control arm, strut and fender were all replaced.
A lot of work has been put into this car and we would like to see it go to a good home who will take care of her and most importantly... drive it!
Functionality wise, the car is perfect, and needs very little attention. However there are a couple odds and ends it needs:
*Boost MAP sensor isn’t working properly, but should be very simple fix.
*Pulley squeak during cold start and until car warms up. This started happening when I put the upper idler on.
Understand that this car is very far from factory specifications. There is no warranty or guarantees implied with the sale of the vehicle and for that purpose, it is sold “AS-IS”
I have a lot of money invested in this project but I'm prepared to move on. $29,900
I don't need to sell it, just don't have time to enjoy it lately and thought it is worth a shot seeing if someone is interested.
The vehicle will be sold through a Ford dealership. Taxes, tags and fees are not included in price.
Thanks,
-Cam
2 by cohen_cam, on Flickr
1 by cohen_cam, on Flickr
23 by cohen_cam, on Flickr
13 by cohen_cam, on Flickr
repaint by cohen_cam, on Flickr
211 by cohen_cam, on Flickr
WOW!!!!!!!! after all that, I am surprised you are selling it!!! one thing for sure, whoever gets this car is getting the best of all worlds. truly a remarkable car and well done. GLWS!!!!!!!!!!!!!!!!!!
Wow! What an amazing car! I hope it goes to a good home. If this had been a year ago I would have considered spending the extra 6K and bought your car. Good luck!
what a machine! I might have missed it, but is that a Black Bullitt? I thought so from previous threads.
Thanks for all the kind words.
Yes it is black. 1 of 181 black ones produced in 2009.
My, my what a prize. I'd think more serious except passing pesky CARB smog regulations would be unsurmountable. Its already a chore with stock Bullitt. GLWS.
Cam, I remember reading the posts as you were doing the mods.
This is a steal, no doubt about it.
Having put SC on 2 s197s including all the other stuff, you are giving some wise person a real deal.
I would put it on EBAY. The Bullitt lover that wants serious power will be out there for you.
Good Luck. Nice engine swap, too.
Discussion Starter · #10 ·
I appreciate it! Maybe I'll stick it on there.
Discussion Starter · #13 ·
Thank you, that truck has taken the Bullitt's place of being a money pit.
Lol
1 - 13 of 13 Posts
