On Oasis it was shown to be built on Dec.18,2007
As far as the Vin decode, here is the decoder ring.
Vehicle Identification Number (VIN) Locator
The vehicle identification number (VIN) is a 17-digit alphanumeric code. The VIN is stamped on a metal tab riveted to the instrument panel, top upper left of the dash. The VIN number is also found on the vehicle certification (VC) label.
If the VIN plate requires replacement, authorized dealers must contact their respective regional office.
Item Description
1 World manufacturer identifier (WMI)
2 Restraint-type code
3 Line, series, body type
4 Engine code
5 Computer-generated VIN check digit
6 Model year code
7 Assembly plant code
8 Production sequence number
World Manufacturer Identifier (WMI)
The first 3 VIN positions are the world manufacturer identifier (WMI).
1ZV — Ford, USA, passenger car
Restraint-Type Code
The fourth VIN position is the vehicle restraint system type code.
F — Active safety belts, all positions — driver and front passenger air bags
H — Active safety belts, all positions — driver and front passenger air bags with side impact air bags
Line, Series and Body Type Code
Positions 5 through 7 indicate vehicle line, series and body type.
T80 — 2-door coupe, base
T82 — 2-door coupe, GT
T84 — 2-door convertible, base
T85 — 2-door convertible, GT
T88 — 2-door coupe, GT500
T89 — 2-door convertible, GT500
Engine Code
The eighth VIN position is the engine displacement and number of cylinders code.
H — 4.6L, OHC, 3-valve, EFI, 8-cylinder
N — 4.0L, SOHC, EFI, 6-cylinder
S — 5.4L, DOHC, 4-valve, EFI, supercharged, 8-cylinder
Computer-Generated Check Digit
The ninth VIN position is a government-assigned, computer-generated check digit code (0-9).
Model Year Code
The tenth VIN position is the model year code.
8 — 2008
Assembly Plant Code
The eleventh VIN position is the assembly plant code.
5 — Auto Alliance International (AAI) — Flat Rock, Michigan (USA)
Production Sequence Number
The last 6 VIN positions are the production sequence number. This number is also used as the vehicle serial and warranty number.
The serial number can also be found on the engine block and transmission.
100001-599999
Hope this helps, Mike........:badgrin:
I see that all Bullitts have these numbers in common:
1ZVHT82H-85------
The only diference is the check digit and the 6-digit production sequence number.
But, again, there is nothing in the VIN that says "Bullitt".
Right, there is nothing in the 17 digit VIN to single it out as a Bullitt. It is of coarse just an option package like the CS or Warrior in Pink Package.
Mike....
Just like the 01s the 08 Bullitt will probly use a different interior trim code and that will be the best way to confrim a Bullitt
I'm not sure about that. I think the color code of a green one will tell it's a Bullitt, but a Black one you may never know without looking at the car.
Jimmy Ray said:
Just like the 01s the 08 Bullitt will probly use a different interior trim code and that will be the best way to confirm a Bullitt
Actually, the interior trim is KW for the 08 Bullitt, which is the same interior code as any GT with dark charcoal leather (like my 07 GT), so it'll be tough to look at codes to tell if it's a real Bullitt in the future! However, pulling internal reports at the dealership will show option code 54B, which is the Bullitt Package.
There was nothing in the VIN# on the 01 to differentiate it as a Bullitt. It's nothing more than an option package. 01s come up on OASIS as GTs, but they also list Bullitt exclusive TSBs whereas the GTs do not.
