Based on some of your posts,it sounds like an Xpipe will produce the higher pitched exhaust note that I,m looking for.Has anyone installed an X pipe using the stock cats,mufs,and pipes and did you like the results.Hate to pitch the new stock parts($s)if just the X will work.Will this mod require some type of computer mod to adjust the air/fuel ratio or will the existing program handle this.Don,t know much about these modern machines.Thanks for your help.
P.S. anyone in or near the N.Y.C./Long Island area with this mod that I could check out?
Dale Robertson
DHG #4120
Dale Robertson
DHG #4120
