1 - 20 of 40 Posts
I Recently Bought Bullitt 4501. The Manual Says To Use 5 Quarts With Filter. I Had To Put In 6 Quarts To Reach The Full Mark. I Assume The Ford Manual Is Wrong?? Has Anyone Else Experienced The Same Problem? Maybe All Of You?
Vern Stewart
Bullitt 4501
Only 5 quarts in mine. I would check it again making sure the dipstick is all the way in.
Check the Bullitt Archives at top of page for much info about the Bullitt.
The following is from the Bullitt Archives:
REFILL Capacities
Fluid
Ford Part Number
Capacity
Brake Fluid
High Performance DOT 3
Fill to line on reservoir
Engine Oil
Motorcraft SAE Society of Automotive Engineers 5W-20 Super Premium Motor Oil
4.7 L (5 Quarts)
Engine Coolant
Motorcraft Premium Engine Coolant Green or Gold
13.3 L (14.1 Quarts)
Power Steering Fluid
Motorcraft MERCON ®ATF
Fill to between MIN and MAX lines on reservoir
Rear axle Lubricant
Motorcraft SAE 75W-140 Synthetic Rear Axle lubricant
2.0L (4.25 Pints)
Fuel Tank
N/A
59.4L (15.7 gallons)
Transmission Fluid
Mobil 1 Synthetic® ATF Automatic Transmission Fluid
3.8L (4.0 Quarts)
Shop Manual shows 3.6 liters!
Windshield Washer Fluid
Ultra-Clear Windshield Washer Concentrate
3.8 L (4.0 Quarts)
Vernon, I'm not sure why but mine takes 6 also to reach the full mark. Has since day one. Everyone else (including the shop manual)says 5 but maybe a few of the cars received a different oil pan or dip stick????? I don't care what people and manuals say, I put 6 to show full.
Have any of you 6 guys measured your stick with the 5 guys?
Only 5 qts in mine including the filter..it is strange that some of the cars take 6 quarts..must be just the DHG cars:D
yeah... the better cars need more oil .....
6 in dhg 1994 as well
6 quarts for the truck engine. 5 quarts for the car engine. Must be a different dipstick. I think someone said this is a truck engine converted to automobile service. Of course my memory says that the 4.6 L engine was first installed in the Lincoln Town Car...:rolleyes:
texasbullitt said:
no leaks, no problems I owuld rather have 6 in and be safe then 5 and ....
weird aint it
Quality is job one...:doubt:
Sorta like "An Army of One".
Former Owner of 2001 DHG1557
You don't want to overfill and get the oil in the pan into the bottom of the crankshaft for those putting in 6 quarts. I would make sure that 6 quarts isn't too much. I don't recall if they put a windage tray on this engine or not, that would help matters but don't over fill it, crank foams up the oil and causes problems you won't like.
I only put 5 quarts in mine.
Lee
1 - 20 of 40 Posts
