1 - 2 of 2 Posts
The 01 Bullitt's rear end is off center to the driver's side a bit...is there any way to change/modify the rear suspension to align it w/out going to an adjustable panhard bar? Maybe replace the upper or lower control arms with something better?
I'm told the oem control arm bushings are so soft that the body can be off center at the rear because of so much slop in the stock suspension setup. It's off maybe an inch...therefore, a move of about 1/2 inch to the right would center it up about right.
you could center it (just push on the fender on driver or passenger side as needed) until the first time you took a corner, it would be off center again :D
only way is to get a new suspension under the back that locks it in place more
1 - 2 of 2 Posts
