Does anyone know if the stock Bullitt shift knob will fit on the stock stalk which comes with the GT short throw shifter from Ford Racing. It also comes with a chrome stalk with white shift knob but I'd rather keep the stock Bullitt knob if I can. Thanks
The shifter from Ford Racing comes with two shift stalks. the plain threaded one accepts the stock knob, the chrome one with the white ball doesn't.
Don't forget to really make it fit you will need a Mustang GT shifter boot.The hole in the Bullitt boot is too small to work properly.Trust me if you want a sanitary install.
The Bullitt boot should work with the stock style shift lever that accepts the stock knob.
The GT IUP boot that has aluminum trim would be a good substitute for the bullitt boot if using the Hurst lever. It looks the same as the Bullitt trim but has the larger hole.
