1 - 3 of 3 Posts
New pic shows location of leak. Fluid trails down copper tube. Do folks still think it is power steering line? The power steering fluild is okay and fluid looks clean. The leak is very slow and amounts to a drop on the garage floor in about 6 hours. The drop of fluid appears to be dark brown or black.
EEWWW! Not so good. Could still be the line, and maybe traveling. That fluid is worse than water for migration and diagostics. That is the p/s pump right? Could be the seal has failed and that is why the fluid is brown, Maybe not, IDK. How low is your fluid? If at all. Trying to get a handle on alot of things here.
Fitting loose?
fitting cracked?
pump cracked?
seal failing?
line wet anywhere else? Like maybe it migrated/worked it's way down the line to the pump.
I was wrong about the color of the power steering fluid. It is red and look good. Had to stick my finger in it to see this.
1 - 3 of 3 Posts
